Plane then sand?
« back to Hand Tools forum
Forum topic by mandatory66 posted 09-06-2016 04:49 AM 1033 views 1 time favorited 17 replies Add to Favorites Watch
View mandatory66's profile
mandatory66
202 posts in 2124 days
09-06-2016 04:49 AM
I was wondering how many people finish their work after just planing their wood with a smoother or scraper. I usually
sand my work to 150 or 220 after planing. If I use a power jointer or planer I hand plane the work smooth and sand. I have experimented finishing some poplar & red oak after just planing and it seems to have a rougher finish than if I sand the work after planing. I have read that finishing after planing allows the grain to pop more than if you sand the work but I don’t see much difference.
17 replies so far
View nightguy's profile
nightguy
213 posts in 655 days
#1 posted 09-06-2016 06:01 AM
This will vary in degree depending on the wood species, sanding tends to open the grain, planing/jointed edges tends to close/compress it by the nature on downward pressure to cut it.
View Lazyman's profile
Lazyman
1933 posts in 1380 days
#2 posted 09-06-2016 04:00 PM
I’ve been having good luck on walnut for example using a card scraper to get a really smooth finish that doesn’t require any sanding. In once case, i used sandpaper to remove an old finish then used the scraper to get it ready for finishing. I am sure that the type of wood will make a difference but on walnut it was amazing how good the wood looked after using the scraper.
View rwe2156's profile
rwe2156
2916 posts in 1474 days
#3 posted 09-06-2016 04:12 PM
Plane or scraper only for me.
:-D
View TheFridge's profile
TheFridge
9436 posts in 1479 days
#4 posted 09-06-2016 04:25 PM
For me, I’ve tried finishing after both sanding or planing and found planing to let’s the figure shine through a bit better in general.
View HokieKen's profile (online now)
HokieKen
4949 posts in 1132 days
#5 posted 09-06-2016 06:03 PM
Smoothing plane, then scraper, then – depending on the type of wood and the grain structure – sandpaper if necessary.
-- Kenny, SW VA, Go Hokies!!!
View Don W's profile
Don W
18707 posts in 2561 days
#6 posted 09-06-2016 11:47 PM
Test, test, test. We call it a Proof of concept in the technology world.
Because YMMV.
View HorizontalMike's profile
HorizontalMike
7754 posts in 2907 days
#7 posted 09-07-2016 01:25 AM
Depends on how many nicks are in the planer blades, and/or how used are your spiral head cutters on your jointer. All said and done, YES, sanding/scraping is more likely needed unless you have NEW blades/cutters.
TheFridge
#8 posted 09-07-2016 01:29 AM
Because YMMV.
- Don W
Pretty much. Find what works.
View OSU55's profile
OSU55
1663 posts in 1983 days
#9 posted 09-07-2016 01:40 PM
Define “rougher finish”. If you mean tool marks, ok, but if the tool edge is not cutting smoother than 200 grit you need to sharpen a lot more often, or you are getting tear out. I sand with 320 to roughen a scraped or planed surface if the sitiuation requires it.
View pintodeluxe's profile (online now)
pintodeluxe
5652 posts in 2806 days
#10 posted 09-07-2016 03:16 PM
It really depends on how you are doing the bulk of the milling. With helical head planers, it has changed my mindset on this. The Shelix head on my planer leaves a surface that is almost ready for finish. I sand with 120 and 150, and that is it.
View dbray45's profile
dbray45
3320 posts in 2770 days
#11 posted 09-07-2016 03:32 PM
I rarely sand but when I do, the coarsest paper that I use is 220 and that would be after I wipe the wood with water to get the feather up. Usually, I use 400 – 600 and go down to 1500 for finish before using pumice and rottenstone for final.
If it has inlay, you don’t want to sand – ever, use a scraper.
-- David in Damascus, MD
mandatory66
#12 posted 09-08-2016 07:54 PM
I see a few answers address using motorized planers & joiners, my question may not have been presented properly. I was asking if many people use sand paper after smoothing a table or board with a hand plane, I am not referring to plane tracks or dull blades or blades with chips in the edge. I can get the board super smooth with the hand plane but when I apply a finish to the board it seems a little rougher than if I had sanded the board. I am using a LN #4 for planing & do not usually need a scraper. (so I think)
Lazyman
#13 posted 09-08-2016 08:28 PM
My understanding is that card scrapers were often used as the sole method of preparing wood surfaces for finishing prior to the early 1900’s. Sandpaper was available before then but not commonly available and likely too expensive for most wood workers. I have also read that in the right hands you can achieve a superior finish with a card scraper but on some woods at least, the surface may be too good and might not take a the finish very well. In that case, lightly sanding after card scraping may yield a more durable finish. In my limited experimentation with a card scraper on walnut, the wood had such a sheen that it almost looked like I had already applied a very light coat of wipe on varnish after scraping.
dbray45
#14 posted 09-10-2016 12:07 AM
Use a wet rag and wipe the board down after you plane it smooth. This roughens the boards – lightly sand that smooth.
View Aidan1211's profile
Aidan1211
198 posts in 819 days
#15 posted 09-12-2016 03:45 AM
Depends on the finish in my experience and how well your plane is setup. If you have a glass smooth surface and you plan on using BLO and shellac you’re golden and the translucence of the grain will be blinding. However if you are using a finish that depends on surface adhesion I’d probably give it a very light scuff with 220.
-- its better to plan on the task at hand than actually doing it........ You look smarter.
