How can I flatten out a piece of plywood?
Forum topic by will2480 posted 329 days ago 750 views 0 times favorited 13 replies Add to Favorites
View will2480's profile
will2480
25 posts in 333 days
329 days ago
Topic tags/keywords: plywood how-to scroll saw scrollsaw scroll question
Today I was at Lowes looking for some small sheets of plywood for a few scroll saw projects that I’d like to create. The projects that I’d like to start working on call for 1/8” thick birch plywood, which Lowes does carry in small sheets (2’x2’, 2’x4’, etc.) The problem I noticed was that most of the sheets of this wood were not very flat. They all seemed to be either bowed or twisted. The sheets are not too expensive (something like $5 for the 2’x2’ sheet), but I don’t want my projects to end up being bowed or twisted.
My question is, can I somehow flatten out this plywood in a quick and easy manner?
I was thinking that I could sandwich a piece between some scrap plywood or OSB and place something heavy like cinder blocks on top of this sandwich to help flatten out the birch. I also considered having to get the birch damp before I make this “sandwich”.
Does anyone know if this wood work, and how long it would take if it does work? Should I just look around for better birch plywood at a different location instead? Please let me know as I’d like to start scrolling soon.
Thanks,
Robert
13167 posts in 929 days
329 days ago
Robert: Is the plywood going to be attached to a frame, which would force it flat or is it just being used as it is.
The plywood might be curved because of unequal moisture mitigation from within the panel. If you hold it in your shop/house it might flatten but probably not.
As to correcting it, I’m not sure.
will2480
329 days ago
-Karson
The project I am currently considering would not be attached to a frame so it couldn’t be forced flat after the fact.
Thanks,
Robert
View IowaWoodcrafter's profile
IowaWoodcrafter
249 posts in 604 days
329 days ago
This is not really an answer to your question. Instead of looking at Lowes or Home Depot I would suggest going to another store, perhaps one that caters to woodworkers. Localy we don’t have any woodworking stores but we have another lumber chain named Menard’s. I have found that Menard’s has a larger selection of quality plywood, and normally cheaper than the other big chains. I can get 1/4, 1/2 and 3/4 Baltic Birch 4×8 sheets at Menards. A 1/2” thick sheet costs about $40, if memory serves me right.
I have purchased 1/4 sheets of oak plywood from both Lowes and Menards. There was a huge difference in quality between the two. The Lowes had a lesser quality oak veneer and the stain was blotchy. To top it off Lowes was more expensive.
-- Owen Johnson - aka IowaWoodcrafter
View Jim Boisvert's profile
Jim Boisvert
6 posts in 352 days
324 days ago
Been here before. I swabbed the plywood with a damp rag on both sides, then laid it over a length of 2×4 and weighted the ends. By bending it “over centre” for a few hours the ply came out staight and true. I then stored it between a couple of sheets of ply wood until I needed it. Just think that the lumber store probably had the stock around for a length of time and perhaps other wood leaned against it and slowly bent it out of true. I also have had success wetting the ply, weighting it over a piece of wood and heating it with a hot iron. Same results but was much more time consuming.
-- Jim, Alberta Canada
Dick, & Barb Cain
5372 posts in 828 days
324 days ago
I think the moisture difference in the two sides causes the bend. Give the concave side a light spray of water, & I bet it will equalize, but that won’t guarantee it’ll stay that way.
Dick, & Barb Cain
324 days ago
Maybe you should get Baltic Birch plywood. I think it’s more stable
Check here for a comparison.
View Betsy's profile
Betsy
1854 posts in 424 days
324 days ago
I’d stay away from most 1/8” ply from the big box stores. I’ve never had much luck with it. I pay a little extra and get the better stuff from Rockler or Woodcraft. The problem with the big boxes are they don’t sell much of it, it stays around, gets roughed up, leans to one side or another, gets out of shape, often has marks you have to sand out, etc. I also, don’t like taking the time to flatten a piece as described above. I’d rather use my time doing my project. I’ve never had a problem with the ply from Rockler or Woodcraft with any of my projects.
Just my 2 cents. Good luck with your project.
-- Betsy - GO BUCKS!
Douglas Bordner
2708 posts in 592 days
324 days ago
Lee Valley/Veritas also has some better quality thin Finnish Birch ply, including bending ply for formed work. Plus the catalogue is like a Sears wishbook for woodworkers, and Robin Lee and company have been kind sponsors of some of our LJ events.
My name is Douglas Bordner, and I have approved this unpaid partisan announcement.
(Sorry folks, The Iowa Caucas has been running non-stop for several weeks in the neighboring state and the ads have been omnipresent.)
View rikkor's profile (online now)
rikkor
8365 posts in 403 days
324 days ago
Take a look at this.
-- Maplewood, MN
View Greg3G's profile
Greg3G
666 posts in 614 days
320 days ago
I would bet the main reason its inexpensive is because its imported from China (that was another Forum topic) As a rule, imports from china are not made to the standards as US or European wood products. Also it was probably shipped via the cargo hold slow boat without regards to the humidity experienced on the open ocean. Can you tell I’m not a fan of Big Box stores. You may want to see if you can find any local cabinet shops and ask them where they get their plywood. Some of these places will sell damaged sheets at a discount. you may be able to pull what you need from one of them.
-- Greg - Charles Town, WV
View Sawdust2's profile
Sawdust2
868 posts in 616 days
320 days ago
www,cherrytreetoys.com has a wide selection of thin ply.
You might find similar locally at Michael’s or Hobby Lobby if they are near you.
View poppy's profile
poppy
2 posts in 311 days
311 days ago
Do Google search on Baltic Birch plywood and get a million hits. There possibly could be a very good dealer close to you
View Sam Yerardi's profile
Sam Yerardi
51 posts in 424 days
311 days ago
I was going to suggest what Dick Cain suggested. If you have to use this particular piece then wet the concave side. I’ve even read in Fine Homebuilding where guys lay the board down on moist grass in the morning on the concave side. The moisture that gets abosrbed expands that side forcing the bow out.
-- Sam
Bookmark And Share This Page
