Mounting workbench casters to supports - help?
Forum topic by rhybeka posted 09-05-2016 05:27 PM 588 views 0 times favorited 3 replies Add to Favorites Watch
View rhybeka's profile
rhybeka
4389 posts in 3323 days
09-05-2016 05:27 PM
Hi all!
I recently rescued a cabinet from in front of a HS trash dumpster, thinking it would make a perfect workshop assembly/power tool storage/ workbench.
It has a four inch skirt/ bottom kick board on it that isn’t tall enough for the workbench wheels I purchased.
My thought was possibly adding 4×4 material at the corners to make them taller but wasn’t sure if this would be the right way to go about it. Scratching my head on this. Any ideas??
-- Beka/Becky - aspiring jill of all trades, still learning to not read the directions.
3 replies so far
View tyvekboy's profile
tyvekboy
1823 posts in 3215 days
#1 posted 09-05-2016 07:04 PM
My suggestion would be to add some material to the skirt so that it would fill the recess.
Then you could add a plywood plate attached too both the cabinet side and the filler. That would give you a good surface to attach the wheels.
The plate might not be necessary if the screws have a good place to be screwed into.
Then you could attach the workbench wheels to the plywood.
Hope that helps.
-- Tyvekboy -- Marietta, GA ………….. one can never be too organized
View Mark Wilson's profile
Mark Wilson
2294 posts in 1265 days
#2 posted 09-05-2016 07:53 PM
When I assembled my store-bought workbench, it wasn’t tall enough. I simply enough pieces of scrap wood to the base with screws to make it taller.
-- Mark
rhybeka
#3 posted 09-05-2016 08:37 PM
Thanks guys :) I thought on it a bit more and combined your suggestions :D cut a ledge out of the 4×4 to fit the skirt and add 2 in to the bottom. Only have one done though since I hand sawed it!
