I need to anchor a bookcase to a wall.
Forum topic by Fricka posted 09-05-2016 02:27 PM 506 views 0 times favorited 4 replies Add to Favorites Watch
View Fricka's profile
Fricka
1 post in 598 days
09-05-2016 02:27 PM
Topic tags/keywords: question
I have a bookcase that I need to anchor into a wall. It’s dimensions are 36 inches wide x 12 inches deep x 7 ft tall. I am positioning it in a corner of two walls. On the 12 inch deep side, the wall is 19 inches wide with a stud at either end. On the back side wall the studs are at the corner, 22/23 inches, and lastly at 38 inches. I have only been able to attach one L brace on the middle back stud…the corner studs do not allow for an L brace to contact the solid portion of the wood over the top….obviously I am a real novice here…this will and has been a learning experience. Any help will be greatly appreciated… Thanks.
View MrRon's profile
MrRon
4720 posts in 3212 days
#1 posted 09-05-2016 02:49 PM
Take a 2×4, 30” long and attach it to the top of the book case with glue and finish nails (3-1/2” side vertical). Attach the 2×4 to the studs at the corner and at 2/23”with 3-1/2” screws. A 2×3 can also be used in place of the 2×4.
View chrisstef's profile
chrisstef
17311 posts in 2975 days
#2 posted 09-05-2016 03:00 PM
Amazon. Furniture tie back straps. I just usedthem on a large hutch in our house. Couple screws and a stud finder is all ya need.
View billibobbabootle's profile
billibobbabootle
2234 posts in 868 days
#3 posted 09-05-2016 03:49 PM
1 brace into the stud will suffice.
View Mike_D_S's profile
Mike_D_S
467 posts in 2183 days
#4 posted 09-05-2016 05:08 PM
So this is maybe not the absolute strongest method and not the cheapest, but will work when you have limited stud access and is easy to remove the furniture if needed.
Start with an aluminum french cleat and then use one of these drywall anchors />http://www.homedepot.com/p/E-Z-Ancor-Twist-N-Lock-75-lb-Medium-Duty-Drywall-Anchors-50-Pack-25310/100040265 every 6” to mount the cleat to the wall.
Mount the bookcase side on the top back of the case, slide the bookcase up to the wall and mark the bottom of the cleat, then position the other side of the cleat about 1/16” low so it will just not touch. Mount the female side to the wall and then position the bookcase by sliding it into place from the side or lifting it up and setting it into the cleat.
Not as good as a couple of good metal brackets into the studs directly, but I’ve used this method for tall CD towers before (I know, what’s a CD?). May not be 100% foolproof against a determined 4 year old playing King Kong, but will definitely prevent accidental tipping. and is relatively strong.
Mike
-- No honey, that's not new, I've had that forever......
