Joint wide boards trick
Forum topic by rwe2156 posted 09-05-2016 12:25 PM 800 views 0 times favorited 9 replies Add to Favorites Watch
View rwe2156's profile
rwe2156
2799 posts in 1386 days
09-05-2016 12:25 PM
I saw this technique in a video and thought I would try it.
Disclaimer: The guard must be removed for this procedure. Do so at your own risk.
After jointing, use a spacer to plane the un-jointed side. Flip the board and plane off the elevated strip of wood left from jointing.
Works great except working without the guard is a bit unnerving.
9 replies so far
View GR8HUNTER's profile
GR8HUNTER
3282 posts in 618 days
#1 posted 09-05-2016 03:01 PM
confused ? as normal ..LMAO
-- Tony Reinholds,Pa. REMEMBER TO ALWAYS HAVE FUN
View ohtimberwolf's profile
ohtimberwolf
749 posts in 2257 days
#2 posted 09-05-2016 03:18 PM
Did you glue that on?
-- Just a barn cat, now gone to cat heaven.
View Aj2's profile
Aj2
1272 posts in 1703 days
#3 posted 09-05-2016 03:32 PM
Since you will have to flip the board end for end will that not put the grain against the cut?
Better off learning how to use a handplane.And doing the minimal amount of work to get a face ready for the planer.
Aj
-- Aj
View pintodeluxe's profile
pintodeluxe
5566 posts in 2719 days
#4 posted 09-05-2016 03:38 PM
Yep, it works. As far as AJ’s comment, you can still send the board either way through the planer. So no more cause for concern with tearout (no more than normal).
rwe2156
#5 posted 09-05-2016 11:08 PM
AJ, no issues with grain you just send the board through the planer either direction.
The board supports the jointed face. After that you flip and plane off the ridge.
View Aj2's profile
Aj2
#6 posted 09-06-2016 03:50 AM
Yes that is very cleaver.
-- Aj
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2214 days
#7 posted 09-06-2016 07:38 AM
Don’t be so foolish as to work without a guard. It’s pretty simple.
pintodeluxe
#8 posted 09-06-2016 03:39 PM
Alaska Guy,
I like the Euro guard. You have to remove the rabbeting ledge for this technique, but the type of guard you suggested would still work just fine.
Thanks for posting.
View jdh122's profile
jdh122
983 posts in 2723 days
#9 posted 09-06-2016 06:36 PM
You can also just run it through the jointer flipping it each time you run it through. Works fine, might take off a bit more wood (not sure). https://www.youtube.com/watch?v=tvakUFUrOXA
I like AlaskaGuy’s idea for a guard…
-- Jeremy, in the Acadian forests
