Sizing Wood
Forum topic by doninvegas posted 06-10-2010 08:58 PM 1078 views 0 times favorited 9 replies Add to Favorites Watch
View doninvegas's profile
doninvegas
334 posts in 2875 days
06-10-2010 08:58 PM
Hello LJ’s.
I’ve been following this site for a long time and finally bit the bullet and joined up. So, I’d thought I’d ask you all something I have been wondering about. I got some really nice Oregon broad leaf maple and I’m going to makes some jewelry boxes. I got the wood 4/4 rough. After milling it 4 square it’s now down to between 5 and 7/8” thick. The boxes are going to be made out of 1/2” stock so the question is do I plane in down to 1/2 or re-saw it to 7/16 and plane it to 1/2”?
Thanks all,
Don
-- "Courage is being scared to death -- but saddling up anyway."
9 replies so far
View CharlesNeil's profile
CharlesNeil
2389 posts in 3838 days
#1 posted 06-10-2010 09:06 PM
big leaf maple , I would let it sit where its at and acclimate, for a couple of weeks, then plane it to final size just before you use it, maple of any sort like’s to move alot, if you re saw it, what you will save is not much and you will probably be glad you didnt, re sawing opens up a diverse moisture issue, meaning it will try to cup to the freshly sawn side, because its wetter on the inside than the outside, even if its kiln dried, allowing it to acclimate at the thicker size will allow it to further dry now that its opened up, so when you are ready to use it, if it moves any as it acclimates, you will be sure to have enough to get your material and be able to further process it flat if need be.
let it dry a while
117063 posts in 3544 days
#2 posted 06-10-2010 09:42 PM
doninvegas
#3 posted 06-10-2010 09:51 PM
Thanks, Charles. I was kinda leaning that way. It is kiln tried to 8% but here in Vegas this time of year it’s not unheard of to go as low as 2% humidity. I’m finishing up a refinish job so it will be a couple of weeks until I use the maple. I also have some salted Alder. Should I do the same with it?
CharlesNeil
#4 posted 06-10-2010 10:55 PM
yep, this is the basis for stabilizing all woods… its a basic..
doninvegas
#5 posted 06-11-2010 01:54 AM
That’s something you can talk about on your new show for new woodworkers.
Thanks.
View tyskkvinna's profile
tyskkvinna
1310 posts in 2953 days
#6 posted 06-11-2010 04:42 AM
This is making me feel a bit better about feeling FRIGHTFULLY guilty when I plane down my 4/4 (all the lumber I get is rough 4/4) to 1/2. Because boy, do I feel guilty about it.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3680 days
#7 posted 06-27-2010 04:37 AM
I want to see you “re-saw it to 7/16 and plane it to 1/2” ;-) Then I want to buy the plane that can add a 16th!
doninvegas
#8 posted 06-27-2010 06:19 PM
Gee, I thought everyone had a planer that added wood. I got mine on sale at HF…LOL
View HallTree's profile
HallTree
5664 posts in 3735 days
#9 posted 06-27-2010 08:28 PM
Putting the question of the size aside, I am thinking: if a board is planed on both sides and then, at the same time, resawed would it then dry out the same on both sides?
-- "Hold on to instruction, do not let it go; guard it well, for it is your life" Solomon
