Need shelf hanging advice
Forum topic by FancyShoes posted 09-04-2016 04:22 PM 473 views 0 times favorited 6 replies Add to Favorites Watch
View FancyShoes's profile
FancyShoes
550 posts in 1331 days
09-04-2016 04:22 PM
How can I hang this to use as a shelf in the bathroom? I want to do free floating, but I want to be able to remove it incase I dislike it later. Its a piece of drift wood.
View DIYaholic's profile
DIYaholic
19597 posts in 2642 days
#1 posted 09-04-2016 04:37 PM
One idea….
http://www.rockler.com/blind-shelf-supports
View GR8HUNTER's profile
GR8HUNTER
3643 posts in 680 days
#2 posted 09-04-2016 05:21 PM
maybe a French Cleat ??
-- Tony Reinholds,Pa. REMEMBER TO ALWAYS HAVE FUN
View waho6o9's profile
waho6o9
8165 posts in 2544 days
#3 posted 09-04-2016 05:32 PM
Install a hex lag into a stud and grind off the hex head, then drill a hole into the side of the
shelf and install 2 of them.
waho6o9
#4 posted 09-04-2016 05:34 PM
FancyShoes
#5 posted 09-04-2016 11:27 PM
All those specialty hardware is pricey, I think I will just lag bolt it from the other side of the wall in my bedroom closet.
View JBrow's profile
JBrow
1348 posts in 887 days
#6 posted 09-04-2016 11:38 PM
FancyShoes,
Using a keyhole router bit, a pair of slots can be routed on the wall-side edge of the shelf. A pair of pan head screws can be installed in the wall at the appropriate distance (the distance between the entry holes in the keyhole slots). The shelf can then be installed on the screws, and with the screws tweaked to the correct depth, sliding the shelf a bit in one direction can lock it to the wall. Of course the head of the screws must fit into the keyhole and the head of the screws large enough to catch on the lips of the slot.
