Help with bonding a spring with a bolt?
Forum topic by Leonardo posted 09-04-2016 12:36 PM 977 views 0 times favorited 28 replies Add to Favorites Watch
View Leonardo's profile
Leonardo
8 posts in 779 days
09-04-2016 12:36 PM
Topic tags/keywords: help spring bolt solder
Hey guys! I’m Leo. I’m new to the forum.
I have been in desperate need of help to permanently attach this spring with this bolt.
It needs to be a permanent bond between these too. I know it’s two kind of metals so soldering it might not work, right? And epoxy might not hold permanently, right?
The spring will be used with the bolt to go in and out of a piece of wood so it needs to resist the twist pressure.
If any of you guys could share your expertise I would greatly appreciate. Thanks!!!
28 replies so far
View Underdog's profile
Underdog
1189 posts in 2185 days
#1 posted 09-04-2016 12:38 PM
Picture might help.
-- Jim, Georgia, USA
Leonardo
8 posts in 779 days
#2 posted 09-04-2016 12:46 PM
Sorry, apparently it didn’t go through the first time.
View diverlloyd's profile
diverlloyd
3122 posts in 2006 days
#3 posted 09-04-2016 01:47 PM
I would weld them together or use silver solder. Silver solder will take a lot of heat unless you use a tig welder then you can localize the heat effected area. From the picture I’m seeing a steel spring and a stainless screw. If that is correct then a weld will be the best method, I would prefer tig welding it but a mig weld would be okay to. Either way you will need some 309 welding wire and some Trimix welding gas. That’s is how I would go about attaching the two. Any way you choose don’t quinch the work piece it will screw up the spring and the weld let it air cool.
Leonardo
8 posts in 779 days
#4 posted 09-04-2016 03:45 PM
Thanks for the reply. I just have to make sure the bond is easy to do fast and cheap since this will be needed to be repeated hundreds of times. Also I can’t have any residue on the side since this will go inside a tight fitting whole. I’m considering welding it but I think gluing would be easier but I don’t know if there is a glue fit for this. If there is i’d prefer gluing since that’s a much easier and more of my level method. (I don’t do much welding so if I can go about not doing it it would be better.)
Thanks
View waho6o9's profile
waho6o9
8438 posts in 2726 days
#5 posted 09-04-2016 04:00 PM
http://www.thistothat.com/cgi-bin/glue.cgi?lang=en&this=Metal&that=Metal
Tig it, save that, if not good luck gluing it and Welcome to Lumber Jocks
View oldnovice's profile
oldnovice
7205 posts in 3517 days
#6 posted 09-04-2016 04:36 PM
Try Bondic!
It is pretty amazing stuff!
View Ger21's profile
Ger21
1075 posts in 3280 days
#7 posted 09-04-2016 04:42 PM
Welding is the only bond that won’t fail.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View GR8HUNTER's profile
GR8HUNTER
4740 posts in 862 days
#8 posted 09-04-2016 05:16 PM
LumberJocks NOT Metaljocks
LMAO …...Welcome 2 LJ’s
View JoeinGa's profile
JoeinGa
7739 posts in 2156 days
#9 posted 09-04-2016 05:18 PM
JB Weld. It’s some dang strong stuff !
View TheFridge's profile
TheFridge
10360 posts in 1635 days
#10 posted 09-04-2016 05:50 PM
Have someone weld it. They probably won’t even charge.
View HerbC's profile
HerbC
1790 posts in 3008 days
#11 posted 09-04-2016 06:02 PM
... I just have to make sure the bond is easy to do fast and cheap since this will be needed to be repeated hundreds of times. ...
- Leonardo
Have someone weld it. They probably won t even charge.
- TheFridge
Fridge, someone might do one or two free, but hundreds is gonna cost him…
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View Woodknack's profile
Woodknack
12372 posts in 2529 days
#12 posted 09-04-2016 06:35 PM
I’m sure it’s obvious but put a big heat sink on that spring or the heat could ruin it.
View jbay's profile (online now)
jbay
2681 posts in 1048 days
#13 posted 09-04-2016 06:48 PM
Instead of a bolt, could you use a piece of all thread that would screw into the spring?
View JAAune's profile
JAAune
1839 posts in 2466 days
#14 posted 09-04-2016 07:28 PM
- jbay
This is the first thought that came to my mind as well. The only thing I’d do different is to thread and glue a nut 1/4” from one end of the threaded rod. Then the spring could be glued or brazed to that 1/4” protrusion.
View MrUnix's profile
MrUnix
6949 posts in 2348 days
#15 posted 09-04-2016 08:38 PM
If you don’t have a welder, find a friend with something like this:
Use it to get the job at hand done, then keep an eye out on CL for a nice used model for cheap. It’s like a hot melt glue gun, but for metal :)
For what you are looking at doing, you don’t need as big of one as shown above – a little 90A model that runs on 120v would be more than enough (like this one at HF for under $100).
showing 1 through 15 of 28 replies
