regular bench plane sharpened for end grain ?
« back to Hand Tools forum
Forum topic by Mambrax posted 09-03-2016 02:33 AM 601 views 0 times favorited 2 replies Add to Favorites Watch
View Mambrax's profile
Mambrax
153 posts in 1487 days
09-03-2016 02:33 AM
Is that possible to sharpen a regular bench plane to be use for end grain ?
if it is possible, what need to be done ?
Thanks for any input.
-- Let's do the best we can !
2 replies so far
View Derek Cohen's profile
Derek Cohen
370 posts in 3964 days
#1 posted 09-03-2016 08:44 AM
If it is a metal plane with a common frog angle (45 degrees), all you need do is sharpen the blade extra well. There is nothing more to do. If fact, there is nothing more that you can do.
As it happens, a plane set up like this should have no difficulty planing end grain extremely well. It is only the high angle planes (50 degrees and above) that will struggle a little.
Regards from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
Mambrax
#2 posted 09-03-2016 12:52 PM
Thanks you for input. Very cool. I will give it a try for sure. Cheers !
