Rigid router bushing locknut
Forum topic by Josh posted 06-09-2010 09:03 PM 1626 views 0 times favorited 7 replies Add to Favorites Watch
View Josh's profile
Josh
103 posts in 3015 days
06-09-2010 09:03 PM
Topic tags/keywords: question router joining
I went to attach a bushing to my router last night and I cannot for the life of me find the locknut. So, anyone know of a good way to replace it? Can you just buy the locknut?
-- Josh, South Jordan Utah
7 replies so far
117085 posts in 3570 days
#1 posted 06-09-2010 09:09 PM
Are you talking about the collet? If so you can buy replacements for most routers
View Josh's profile
Josh
#2 posted 06-09-2010 09:21 PM
No, I’m talking about the locknut that the router bushing screws on to
Its the two pieces in the top right at this link
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3280 days
#3 posted 06-09-2010 09:41 PM
Try Freud part # FT1200. It should work. The nut is sold separately.
If you don’t already have a source for Freud—PM me.
Kent
-- http://shepherdtoolandsupply.com/
View Peter Oxley's profile
Peter Oxley
1426 posts in 3868 days
#4 posted 06-09-2010 09:54 PM
@Kent Shepherd – The Amazon listing for the FT1200 says that the nut only works with Freud template guides. I don’t know if that’s accurate.
@Josh – I have an extra one I could live without. If you don’t track down what you need, PM me your address and I’ll mail you one.
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
View Josh's profile
Josh
#5 posted 06-09-2010 10:18 PM
Thanks Peter, I’ll definitely do that if I can’t find one. The amazon link is just showing an example of what I need. I have the Rigid bushings not the freud but I couldn’t find Rigid bushings on amazon.
Kent Shepherd
#6 posted 06-11-2010 10:40 PM
Josh, I’m not positive, but I believe they are all the same. I use my Freud nuts and templates interchangably with my Porter Cable templates and my theaded Bosch template adapter.
Since the templates themselves are universal in that style, I would think the thread pattern would be also.
I’ll double check mine tonight.
A shameless plug for actual stores—-You can take your part in and check it out. Try doing that online. ( I know that’s not an option for many of you)
View allthunbs's profile
allthunbs
25 posts in 2912 days
#7 posted 06-16-2010 01:57 PM
What size? 1 3/16” or 1 1/2”? LeeValley carries both, OakPark carries 1 1/2” many other store fronts carry similar products. I’m not sure but it is also possible that HD would have some or may have a kit for you to buy. Does Ridgid actually supply brass insert/template guides? Finally a manufacturer that learned! But, I bet they still use spindle locks :-(
