Oversized router bits
Forum topic by mnausa posted 09-02-2016 01:30 AM 574 views 0 times favorited 4 replies Add to Favorites Watch
View mnausa's profile
mnausa
33 posts in 1864 days
09-02-2016 01:30 AM
Topic tags/keywords: cherry router milling
I am making a hardwood countertop out of 2.5” thick Brazilian Cherry. I am wanting to put something like a ogee profile on the front edge. Where can I find those oversize router bits at? All I can find is just regular size.
Or, am I going to have to use 2 or 3 different regular bits to create what I want?
-- Mike, Mississippi, www.facebook.com/pages/Wood-b-Perfect/169836013081912
View Lazyman's profile
Lazyman
2288 posts in 1473 days
#1 posted 09-02-2016 01:48 AM
I think that you will only find something of that size in a shaper cutter. I don’t ’ think that they make router bits that large. You will probably have to use multiple bits.
You might also look to see if the you can find a molding cutter head for your table or radial arm saw but those might not be big enough for your needs either.
View TheFridge's profile (online now)
TheFridge
9876 posts in 1571 days
#2 posted 09-02-2016 01:53 AM
Shaper bits.
View MadMark's profile
MadMark
979 posts in 1538 days
#3 posted 09-02-2016 02:48 AM
Good luck – routing jatoba scares me with a tall (2-1/2”) bit – been trying to make casing molding – decided to wait and buy a table shaper.
Jatoba is stringy when routing and can run with the grain.
Beautiful wood tho, gotta weigh a ton.
M
View ksSlim's profile
ksSlim
1281 posts in 2975 days
#4 posted 09-02-2016 10:42 AM
Cut an angle on the show edge equal to the largest point that want the profile.
with a handheld router or 2 or 3 passes on a table you should achieve a decent profile.
Practice on scrap. That’s how we do it with moulding planes.
slim
-- Sawdust and shavings are therapeutic
