General model 450
Forum topic by SwampDonkey772 posted 09-01-2016 04:25 AM 543 views 0 times favorited 6 replies Add to Favorites Watch
View SwampDonkey772's profile
SwampDonkey772
38 posts in 802 days
09-01-2016 04:25 AM
Ok lumberjocks I have a dilemma. Found a General model 450 for sale with a 52 inch beismeyer fence. It’s 3 phase 5 HP with a14” blade what would i need to do to run it in my garage? He has it for 350. Good saw? Good deal? Is it an upgrade from a rockwell contractor saw? Any and all answers appreciated.
View MrUnix's profile
MrUnix
6830 posts in 2256 days
#1 posted 09-01-2016 05:27 AM
It s 3 phase 5 HP with a14” blade what would i need to do to run it in my garage?
- SwampDonkey772
240V outlet and a VFD. Also, according to the manual, that is a 12” saw, not 14”. It also recommended a 2hp or 3hp motor, so verify the motor installed and it’s rated amperage.
SwampDonkey772
#2 posted 09-01-2016 05:29 AM
Here is the plate on the machine
View GR8HUNTER's profile
GR8HUNTER
4156 posts in 769 days
#3 posted 09-01-2016 02:30 PM
cant even read it…... looks like it was tampered with
SwampDonkey772
#4 posted 09-01-2016 02:33 PM
No it was stamped in there. it says model 450 voltage 220. Cycles 6. Hp 5 amps 13.7 ph 3
GR8HUNTER
#5 posted 09-01-2016 02:49 PM
IF its 3 phase ….... then you need to have an electrician in to install a phase converter …. to be able to run this in garage
View Woodknack's profile
Woodknack
12097 posts in 2437 days
#6 posted 09-01-2016 05:05 PM
Check the cost of a 1ph replacement saw motor from Grizzly .
