adjusting Jet jointer
Forum topic by BrianA posted 06-08-2010 02:32 AM 3235 views 0 times favorited 9 replies Add to Favorites Watch
View BrianA's profile
BrianA
76 posts in 3264 days
06-08-2010 02:32 AM
I have a jet closed stand jointer (JJ-6csx) and cannot get the infeed table high enough. I turn the crank on the infeed table and it will only go just past the 1/8 mark. Lubed the threads, but cannot turn it an more. Could the blades be set high? I bought it used and have never changed the blades
Brian
9 replies so far
View j_olsen's profile
j_olsen
155 posts in 3406 days
#1 posted 06-08-2010 02:40 AM
Brian
I would suggest calling Jet support
I’ve called them a couple times and they have been very quick to help—great customer support in my book
-- Jeff - Bell Buckle, TN
View DrewM's profile
DrewM
176 posts in 3234 days
#2 posted 06-08-2010 02:45 AM
My jointer has a stop at 1/8” that stops the table in both directions. Is this happening with yours?
-- Drew, Delaware
BrianA
#3 posted 06-08-2010 03:41 AM
There is a scale only on the infeed table. Cranks work independently from each other. Drew is that what you meant by both directions? I can crank the table down, but just cannot get it high enough and the last turns of the crank is very stiff and hard to turn.
BrianA
#4 posted 06-08-2010 04:30 AM
DrewM
#5 posted 06-08-2010 04:31 AM
Sorry if you assumed i had a Jet jointer, I own a bridgewood model. Mine has a pin that clicks into a hole on the in-feed table only when the table is at the 1/8” marker. Its a round knob right on the front of the scale that you just pull out and crank the wheel until it passes 1/8”. I’m looking at pictures of your jointer and cannot see the pin mine has for a stop. You can see the knob in this picture of my jointer.
-- Drew, Delaware
BrianA
#6 posted 06-08-2010 04:32 AM
BrianA
#7 posted 06-08-2010 04:35 AM
Drew,
I have 2 cranks on the front and that round knob on the back. I will try moving that when I turn the crank.
Thanks
BrianA
#8 posted 06-08-2010 03:45 PM
Drew,
Thanks That was it! Pulled it out and it turned. Not sure of the pint of having the stop there?
Brian
DrewM
#9 posted 06-08-2010 06:02 PM
No problem Brian, I think the stop is there to keep you from making to large of a first cut. It’s easily bypassed so I assume its there more as a reminder instead of a true safety feature.
-- Drew, Delaware
