Don't Trust Command Strips to Hold Your Projects :/
Forum topic by I_like_meats posted 08-29-2016 05:48 PM 1126 views 0 times favorited 10 replies Add to Favorites Watch
View I_like_meats's profile
I_like_meats
36 posts in 852 days
08-29-2016 05:48 PM
Topic tags/keywords: clock humor tip sadness teardrops on my guitar
Made this clock for my apartment in Auburn, which unfortunately doesn’t allow nails or screws in the walls. So I hung it with a command hook… bad decision. Stayed strong for 2 weeks but fell this morning and broke the clock completely in half. I think I’ll cut it up and make coasters or something else small. Just be wary of putting your prized projects in the hands of adhesive hooks like I did :(
10 replies so far
View gargey's profile
gargey
958 posts in 743 days
#1 posted 08-29-2016 05:58 PM
That’s a stupid rule. There is no other appropriate way to hang things. That would suggest a de facto policy of no wall art etc, which is stupid.
Use a screw or a nail, and putty it when you move out.
View Gene Howe's profile
Gene Howe
10368 posts in 3396 days
#2 posted 08-29-2016 05:59 PM
That is really sad. Couldnt it be glued. I’d try it before cutting it up. Then move.
View billibobbabootle's profile
billibobbabootle
2233 posts in 867 days
#3 posted 08-29-2016 06:10 PM
Just out of curiosity, did the strip stay stuck to the clock or the wall?
Was the wall textured?
Nevermind, just saw that it was a hook…
View bobasaurus's profile
bobasaurus
3407 posts in 3152 days
#4 posted 08-29-2016 06:11 PM
I would use a nail or screw anyways, then use jointing compound to cover the hole if you move out. That’s depressing. Maybe cut it and make two clock halves, or put something interesting in the middle?
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View HokieKen's profile
HokieKen
4747 posts in 1106 days
#5 posted 08-29-2016 06:34 PM
That’s a gorgeous clock. Get a couple of clamps and glue that sucker back together ASAP!
-- Kenny, SW VA, Go Hokies!!!
View AZWoody's profile
AZWoody
1325 posts in 1191 days
#6 posted 08-29-2016 07:59 PM
back in college my friends who were in apartments would fill any nail holes with toothpaste after the school year was over. Worked surprisingly well.
billibobbabootle
#7 posted 08-29-2016 08:04 PM
Using sewing needles is another trick that leaves very small holes but are surprisingly strong.
View Woodknack's profile
Woodknack
11483 posts in 2348 days
#8 posted 08-29-2016 08:35 PM
I always used nails and filled the holes with wet toilet paper. It dries white and blends in.
billibobbabootle
#9 posted 08-29-2016 08:36 PM
- Rick M.
It doesn’t start out yellow does it? :>/
View JeffP's profile
JeffP
573 posts in 1359 days
#10 posted 08-29-2016 11:33 PM
oh, that’s just a “flesh wound”. I’m sure you could fix it. Sorry to hear about your bad luck.
I, for one, have had good results with real 3M command adhesive strips. 4 pieces of that have been holding my toilet paper dispenser to a tile wall for about 6 months now.
Before that, I had tried some off-label double sticky tape. That lasted just a couple days.
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
