Wipe-on and non wipe-on finishes
Forum topic by Jeff posted 06-07-2010 04:27 PM 1042 views 0 times favorited 7 replies Add to Favorites Watch
View Jeff's profile
Jeff
10 posts in 2933 days
06-07-2010 04:27 PM
Is there a difference between polyurethane that can be wiped on and ones that can’t? Minwax states on their website that their wipe-on variant is just thinner than regular polyurethane.
I always brush on poly but I can never get rid of all the air bubbles or brush strokes so I want to trying wiping it on instead.
7 replies so far
117113 posts in 3599 days
#1 posted 06-07-2010 04:33 PM
Basically wipe ons are thinned down versions of the brush on versions.
View Jeff's profile
Jeff
#2 posted 06-07-2010 04:40 PM
I see, thanks. I already have a gallon of the regular poly so it saves me the trouble of having to buy another haha
View drax0r's profile
drax0r
18 posts in 2932 days
#3 posted 06-07-2010 05:35 PM
I’ve had pretty good luck with creating my own “wipe on” poly by thinning brush on with mineral spirits.
I just experimented with ratios until I got to a point where I wasn’t bubbling or leaving sponge marks.
I usually do at least 1 extra coat if I’ve thinned my varnish.
View Milo's profile
Milo
869 posts in 3341 days
#4 posted 06-07-2010 05:36 PM
One way to get rid of air bubbles when applying finish is to use a small hair dryer on a low, non heat setting and let it gently blow across the surface of your piece. That will disrupt the surface tension of the bubbles and pop them.
That’s what I used to do when I used to refinished tabletops.
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
View Jeff's profile
Jeff
#5 posted 06-07-2010 05:48 PM
I’ve always avoided wiping on varnish because it was time consuming but I think it’s worth the time if I don’t have to deal with bubbles or brush strokes.
When I do thin the poly, how much should I thin it by? 10%? 20%?
View Randy Sharp's profile
Randy Sharp
363 posts in 3694 days
#6 posted 06-07-2010 05:57 PM
Jeff, I’ve had good results by hand-wiping my first coat. I get a smoother, more thorough base in which to follow up with brushing subsiquent coats. I think it lets me get better coverage into the wood grain, without having it raise as much as first-coat-brushing. Hope this helps.
-- Randy, Tupelo, MS ~ A man who honors his wife will have children who honor their father.
View Jeff's profile
Jeff
#7 posted 06-07-2010 05:59 PM
Randy, do you choose to brush on your subsequent coats to save time?
