pre stain conditioner for plywood
Forum topic by jtlighting posted 06-07-2010 06:44 AM 14099 views 0 times favorited 12 replies Add to Favorites Watch
View jtlighting's profile
jtlighting
27 posts in 3074 days
06-07-2010 06:44 AM
hey all im almost ready to finish “the indestructable” dresser for the “human wrecking ball” and i have read somewhere that before i stain the plywood i should use a pre stain conditioner so my 2 questions would be #1 is this a good idea ? #2 how to i apply this is it like applying a stain? oh i almost forgot should i sand after application of this conditioner before staining or should i just stain over it ? any help is appreciated as always or any alternative methods would help me out as well thanks
-- TO CUT IS TO CREATE.....
12 replies so far
View CharlesNeil's profile
CharlesNeil
2436 posts in 4014 days
#1 posted 06-07-2010 01:50 PM
what is the wood and what is the preconditioner you have
16276 posts in 4362 days
#2 posted 06-07-2010 02:47 PM
I’ve used Minwax water based pre-stain conditioner. Because it is water-based it tends to raise the grain a bit, so a light sanding is necessary.
If you are using just plain old pine plywood, the conditioner will help your stain be less blotchy, but if you are using a hardwood plywood, I don’t think it’s necessary.
View 8iowa's profile
8iowa
1581 posts in 3905 days
#3 posted 06-07-2010 03:03 PM
With veener thickness of about three sheets of paper, modern plywood will not tolerate much sanding. For a pre-conditioner I like to use de-waxed shellac (Zinsser) mixed 50-50 with denatured alcohol.
View tyskkvinna's profile
tyskkvinna
1310 posts in 3129 days
#4 posted 06-07-2010 03:27 PM
I tried using the conditioner extensively on plywood… and couldn’t honestly see much, if any, difference for my effort.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View drax0r's profile
drax0r
18 posts in 3054 days
#5 posted 06-07-2010 04:12 PM
I used the oil-based Minwax conditioner on all softwoods before I stain – including pine plywood.
I didn’t run side-by-side comparison on pine, but the piece I finished looked really good. And it does definitely make a difference when comparing test stains on other pine.
To apply, I use either a lint-free rag or foam brush. I just basically wet the surface down. You want it to be moist, but you don’t want want puddles. :)
If you’re using oil based stain, you’d want to use the oil based conditioner, so sanding between conditioner and stain isn’t necessary.
After 5-10 minutes it’s ready for the first coat of stain.
Make sure you don’t wait too long before applying the first coat of stain after conditioning. I made the mistake of going to bed after conditioner once. When I applied stain the next day it looked horrible. Apparently after its been on the wood for a while (1-2 hours) it closes up the pores and stain won’t stick.
Depending on the weather, I like to wait 10-20 minutes after application to begin applying stain.
  • This assumes you’re using pine plywood – if you’re using a hardwood ply (oak veneer, for example) you can probably just skip the conditioning all together.
117234 posts in 3720 days
#6 posted 06-07-2010 04:26 PM
Charle Neils Blotch control works great.
jtlighting
#7 posted 06-07-2010 06:21 PM
sorry folks its just regular old fashion cabinet grade plywood from my local big box store thanks i dont want to paint it and im using a minwax oil base stain from brought from the same place thanks all oh i almost forgot the face frame /edging is 1/4 in poplar if this helps any
jtlighting
#8 posted 06-07-2010 06:22 PM
oh by the way i havent brought the conditioner as of yet this was the original basis for my inquiry
View Stevinmarin's profile
Stevinmarin
838 posts in 3219 days
#9 posted 06-07-2010 06:46 PM
Whenever I stain pine, I apply Minwax Conditioner. But to tell you the truth, I still get blotching. I think a shellac sealer is a good way to go.
-- Entertainment for mere mortal woodworkers. http://www.WoodworkingForMereMortals.com
View Beeguy's profile
Beeguy
179 posts in 3780 days
#10 posted 06-07-2010 08:49 PM
Although I have had success with a wash coat of shellac, I have to agree with Jim, Charle Neils Blotch control works great.
-- Ron, Kutztown, PA "The reward is in the journey."
View hObOmOnk's profile
hObOmOnk
1381 posts in 4271 days
#11 posted 06-07-2010 09:32 PM
Avoid the low end MinWhacks consumer products.
Try Zinsser SealCoat shellac. It’s a 2 lb. cut of dewaxed shellac that is formulated to have a long shelf life.
For use as a sealer, dilute it 50/50 with denatured alcohol.
-- 温故知新
View stnich's profile
stnich
120 posts in 3068 days
#12 posted 06-08-2010 04:58 AM
I’ve used Minwax pre stain conditioner both oil based and water based depending on what I’m staining with. I also use a lot of poplar 1x material and birch plywood in making clocks that I sell on our website officeclocks.com. When I use poplar and birch plywood I use Zar stains that I find work very well. When I use oak on our clocks I use Minwax oil based wood finish that works well on oak. Proper surface preperation ie. sanding is equally as important as a conditioner. I’d like to try Charles Neils blotch control but haven’t had a chance yet.
