4 Lead Motor Wiring Problem
Forum topic by ChunkyC posted 06-06-2010 05:05 AM 4600 views 0 times favorited 7 replies Add to Favorites Watch
View ChunkyC's profile
ChunkyC
856 posts in 3248 days
06-06-2010 05:05 AM
Topic tags/keywords: electrical motor
I’ve got a 4 lead, 1 phase, 115V, single speed, Capacitor start motor that I want to use. It’s a Chinese made motor that doesn’t seem to conform to any standard, at least none that I know of or can find on the WWW. It doesn’t even have a HP rating on the motor let alone a wiring diagram!
It has Black, White, Red and Blue wires in the pecker head. On a typical 1 phase capacitor start motor you would tie L1-T8-T1 and L2-T4-T5 together. I took the cover off of the capacitor and it has Black and White wires coming off of the two terminals.
My best guess for wiring this gem would be to tie L1-Black-Red together and L2-White-Blue together.
Anyone have any thoughts? Any way of determining the start and run windings, maybe using a multimeter? Think it might be reversible by swapping the Red and Blue???
Thanks,
Chunk
-- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135
7 replies so far
View MarkwithaK's profile
MarkwithaK
370 posts in 3172 days
#1 posted 06-06-2010 07:12 AM
Are you dead certain that this motor is meant for your application? The colors you described seem more like a blower motor for a furnace/air handler….Black being high, blue-medium , red-low and white neutral.
-- If at first you don't succeed then maybe skydiving isn't for you.
TopamaxSurvivor
18266 posts in 3670 days
#2 posted 06-06-2010 07:21 AM
I think I would try that first.
ChunkyC
#3 posted 06-06-2010 01:10 PM
MarkwithaK: Dead certain. The motor came off an old Chinese made Drill Press.
TopamaxSurvivor
#4 posted 06-06-2010 09:19 PM
Use a VOM to check to see if the Blk and Wht are the cap leads in the pecker head. Put it on for a couple minutes, reverse the leads and see if you get a voltage blip on the meter as it drains off. Do this on the volts scale. An analog meter will be best to check.
ChunkyC
#5 posted 06-06-2010 09:44 PM
Thanks for the tips! Looks like my guess was correct.
HOT-Black-Red and COMMON-White-Blue and the motor turns CW. I didn’t try swapping the cap leads to see if it would run CCW since CW is the direction that I want.
Thanks again.
cc
View Dave Price's profile
Dave Price
90 posts in 2968 days
#6 posted 06-06-2010 09:46 PM
i agree with Mark sounds like a 3 speed motor, did the drill press have a speed selector switch on it? ive never seen one like that but that don’t mean that’s there’s not. that motor might not be OEM either, i souped up a small drill press once with a larger motor “worked great”
-- Dave Price , Roswell New Mexico
Dave Price
#7 posted 06-06-2010 09:47 PM
sorry didn’t see your post while i was posting. glad you figured it out
