Please recommend a good flat-top 10" sawblade
Forum topic by live4ever posted 06-06-2010 02:20 AM 2149 views 0 times favorited 4 replies Add to Favorites Watch
View live4ever's profile
live4ever
983 posts in 2979 days
06-06-2010 02:20 AM
I’ve been trying my hand at box-making lately. It’s a lot of fun. I made a lovely spline key jig (thank you Doug Stowe) but found out the hard way that ATB sawblades aren’t so great for splines. So, for my current project, any recommendations on easy ways to clean them up (I can’t think of a good way to do it).
And for the future, what’s a good flat-top blade? All my sawblades (40T, 50T, 60T, 80T) happen to be ATBs.
View stevenmadden's profile
stevenmadden
174 posts in 3058 days
#1 posted 06-06-2010 02:40 AM
I have a 50T ATB made by Amana, every third tooth is flat.
Steve
View Ger21's profile
Ger21
1074 posts in 3100 days
#2 posted 06-06-2010 02:54 AM
View knotscott's profile
knotscott
7983 posts in 3344 days
#3 posted 06-06-2010 03:14 AM
The vast majority of flat top grind blades are found in bulk rippers…usually with 10-24 teeth. Decent full kerf 24T FTG blades include the Freud LM72, Infinity 010-024, DeWalt DW7640, DW7124, Amana RB1020 (20T), CMT 201.024.10, and Forrest makes a 20T FTG. There is a 36T Freud made thin kerf FTG that came with the original Ryobi BT saws, and there’s a Bosch 60T FTG TK CB1060L. A true 100% FTG blade is the only grind that’ll leave a truly flat bottom. Blades with combination teeth are flatter than ATB grinds but the non-flat top teeth protrude above the flat top teeth and will leave grooves accordingly.
teenagewoodworker
2727 posts in 3737 days
#4 posted 06-06-2010 03:21 AM
you can also try a 7 1/4” blade. For cutting splines there isn’t a need for more than that and Freud makes some good 7 1/4” and 6 1/4” blades that I believe are flat top grind. I’ll have to check but I have thier 40 tooth 6 1/4” blade and its very nice.
