Sanding machine
Forum topic by Edwin posted 1077 days ago 819 views 0 times favorited 4 replies Add to Favorites Watch
View Edwin's profile
Edwin
67 posts in 1163 days
1077 days ago
Topic tags/keywords: question
I was thinking about building a overhead sanding machine. I pretty much have it figured out how to build it but one question keeps poping up, Ive’s got a 1750 RPM motor spinning a 4” shaft connected to two pillow blocks…...
Here is the question (Don’t laugh) when you feed the wood in what keeps it from flying out the other side???
-- Ed Port Republic
View levan's profile
levan
312 posts in 1144 days
#1 posted 1077 days ago
all the manufactured machines rotate, so the board would actually be pushed back to the infeed side
-- Lynn "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View richgreer's profile
richgreer
4474 posts in 1240 days
#2 posted 1077 days ago
levan is right. The drum should spin such that the pressure will be to the input side.
Are you using pulleys that speed up the rotation of the drum? I ask because, in my experience, 1750 is too slow for optimum performance. Most commercial sanders with 3 – 4 inch drums are spinning around 3000 rpm.
Edwin
#3 posted 1077 days ago
I was thinking about 3” sprockets, that should speed up the the speed of the drum, I’m open to sugesstion ???
-- Ed Port Republic
View rance's profile
rance
3854 posts in 1325 days
#4 posted 1077 days ago
Ed, The size of one sprocket has little to do with the speed. It is more the ratio of size on the motor shaft and the drum shaft. The ratio of the two sizes can be used to increase or decrease the resultant speed of the drum. I’d strongly suggest you look at the design from ShopNotes before moving past your design phase. Goole “Drum sander”. I’m building the ShopNotes model but with some modifications. I’m building it as a stand-alone as opposed to running it from my saw. I’m also motorizing the platten using a rotisori motor. In any case, I think you’ll love your new machine. Go for it.
