Can glues be dyed?
Forum topic by lobro4 posted 06-05-2010 04:59 AM 1068 views 0 times favorited 5 replies Add to Favorites Watch
View lobro4's profile
lobro4
203 posts in 3182 days
06-05-2010 04:59 AM
Does anybody have any knowledge as to whether wood glues can be dyed? Glues are water soluble but does that mean a water soluble dye could be added? My organic chemistry days are too far behind me now to figure it out off the top of my head. I was thinking about accenting some joint lines on a panel glue up and how crazy I could get with it.
-- Rock Chalk Jayhawk Go KU!!
5 replies so far
117063 posts in 3546 days
#1 posted 06-05-2010 05:02 AM
They sell glues that fluoresce with black light . So I would say do a test on some scrap wood and see what happens.
View pmayer's profile
pmayer
1026 posts in 3034 days
#2 posted 06-05-2010 05:03 AM
if you execute the joint properly, you should not be able to see the glue, regardless of the color. If the glue shows on any joint, you have either not done a good job on the joint, or not cleaned it up properly. I would look at other ways to achieve the effect that you are looking for, such as an inlay.
View miserybob's profile
miserybob
88 posts in 3014 days
#3 posted 06-05-2010 05:20 AM
You can certainly color epoxy, I do it all the time. I swear I saw some colored CA glues at woodcraft a while back, but I can’t find anything about it online… maybe I imagined it!
I think, though, if you’re just trying to accent a line on a glue up, you’ll be hard pressed to get it to come out even… better to use a small router bit and fill with epoxy IMHO.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3450 days
#4 posted 06-05-2010 08:15 PM
You can stain or color polyurethane.
-- Wayne - Plymouth MN
View Knothead62's profile
Knothead62
2584 posts in 2930 days
#5 posted 06-05-2010 09:32 PM
Colored epoxy is used for a marbling effect in building custom fishing rods. Go to www.mudhole.com for a marbling kit. This company is the world’s largest supplier of rodbuilding components and supplies.
