would you redo this mdf laminate
Forum topic by maxhall posted 08-24-2016 02:54 PM 983 views 0 times favorited 12 replies Add to Favorites Watch
View maxhall's profile
maxhall
80 posts in 2346 days
08-24-2016 02:54 PM
Hey guys building an outfeed extension table for my saw and I lamintated the two pieces of mdf together. I used clamps on the long edges and some weights in the middle but didn’t clamp the other two sides (forgetful/ignorance). I have about 8 more clamps than I used which is the frustrating part. Should have slapped some 2×4’s undernearth so I would have clearance on all 4 sides.
So my question is should I redo the mdf layers or don’t worry about it since it will be edged with wood and skinned with laminate. Here is a link to a video showing the extension I plan on building.
https://www.youtube.com/watch?v=Pt6s3rzF8jg
12 replies so far
View bbasiaga's profile
bbasiaga
1240 posts in 2140 days
#1 posted 08-24-2016 03:50 PM
Doesn’t need to be super flat for an out feed table. If you’re worried about it splitting you could add some screws which will be hidden under your laminate. I think it’s fine.
Brian
View jwmalone's profile
jwmalone
769 posts in 847 days
#2 posted 08-24-2016 04:01 PM
No one else would know. But you will, it will haunt your dreams at night and one day it will blow up. Na just kidding I think Brain is right, no big deal in that situation.
-- "Boy you could get more work done it you quit flapping your pie hole" Grandpa
View Underdog's profile
Underdog
1186 posts in 2180 days
#3 posted 08-24-2016 04:02 PM
I wouldn’t redo it. It’s not like it’s going to come apart. You’re just sliding wood across the top. Long as it’s flat enough, I’d not worry about it.
-- Jim, Georgia, USA
View GR8HUNTER's profile
GR8HUNTER
4724 posts in 857 days
#4 posted 08-24-2016 04:06 PM
NO WORRIES …...just do it
View Cooler's profile
Cooler
299 posts in 988 days
#5 posted 08-24-2016 04:41 PM
I laminated two sheets of MDF once and I pre-drilled countersunk holes on one sheet (about 8 inches on center).
I painted on the glue and then drove in all the screws. As I recall I just left the screws in. No clamps.
To make my job easier I drove several thin brads into once surface and clipped them so only about 1/16” was showing. It kept the boards from sliding around on the glue. This is a process I use frequently when gluing up. The nails never show and are not part of the joinery; just part of the positioning.
-- This post is a hand-crafted natural product. Slight variations in spelling and grammar should not be viewed as flaws or defects, but rather as an integral characteristic of the creative process.
maxhall
#6 posted 08-24-2016 09:40 PM
Thanks everyone, I decided to drill and countersink a copious amount of screws… Should do the trick.
View TravisH's profile (online now)
TravisH
613 posts in 2080 days
#7 posted 08-24-2016 09:45 PM
I don’t think you added enough screws. Perhaps you should wrap it a few times with duct tape also.
View jbay's profile (online now)
jbay
2672 posts in 1044 days
#8 posted 08-24-2016 09:51 PM
Yeah, you probably should put another screw in the middle of each square, just in case. LOL
I think your underestimating the strength of glue, that, or you just have a lot of time and enjoy doing stuff.. ;)
maxhall
#9 posted 08-24-2016 09:59 PM
I don t think you added enough screws. Perhaps you should wrap it a few times with duct tape also.
- TravisH
Great suggestion…going downstairs to add a few layers of tape
View DrDirt's profile
DrDirt
4464 posts in 3887 days
#10 posted 08-24-2016 10:04 PM
screws work – not just don’t hit any when you route groves for the miter slot extensions
Delamination was not going to be a problem even before.
19060 posts in 2001 days
#11 posted 08-24-2016 10:10 PM
For something like that I don’t mess with clamps. Just glue and screws. You’ll be fine.
maxhall
#12 posted 08-24-2016 10:46 PM
I made sure to mark where the miter slots were, so I should be set on that front.
