What Hinge Do I Need?
Forum topic by Gene Howe posted 08-23-2016 05:23 PM 681 views 0 times favorited 6 replies Add to Favorites Watch
View Gene Howe's profile (online now)
Gene Howe
10827 posts in 3546 days
08-23-2016 05:23 PM
For a case about 44” long X 7” deep X 12” wide. The case, excluding the bottom will be from 5/8” hardwood.
It’s a Centennial rifle display case and won’t be opened and closed often.
I wanted to use quadrant hinges but I’m not sure they would be strong enough. I do not want to use a piano hinge.
Any suggestions from the brain trust here?
View splintergroup's profile
splintergroup
2253 posts in 1340 days
#1 posted 08-23-2016 05:49 PM
With a lid that long and narrow, I’d worry about any bowing of the wood messing up the fit. For these situations, I like (of course) , piano hinges or at least 3 or more butt hinges. If the lid is the typical framed glass panel, I’d go butt hinges since you would have minimal room.
If the lid is solid (display case is like a box on a table):
Quadrant hinges (beefy ones) will work since they essentially are butt hinges with an opening limiter, but they wont control any bowing unless you have a butt hinge located in the center.
An easier alternative to quadrants would be to use butt hinges with lid stays (easier to install as well).
View shipwright's profile (online now)
shipwright
8066 posts in 2915 days
#2 posted 08-23-2016 06:33 PM
Come on Gene. ............ http://lumberjocks.com/shipwright/blog/series/4096
You knew I’d suggest that one. :-)
Gene Howe
#3 posted 08-23-2016 08:12 PM
Thanks splintergroup.
Hey Paul, I didn’t forget those hinges but, these cases are freebies. Down and dirty for this project.
View waho6o9's profile
waho6o9
8360 posts in 2694 days
#4 posted 08-23-2016 11:18 PM
How about SOSS concealed hinges? They have barrel hinges as well.
http://www.soss.com/invisible-hinge.html
Gene Howe
#5 posted 08-24-2016 01:15 PM
Thanks guys.
View Grumpymike's profile
Grumpymike
2289 posts in 2433 days
#6 posted 08-24-2016 11:27 PM
Hi Gene,
Rockler carries a 105° hinge that is 7 inches long and looks like and works like a piano hinge, but much smaller.
If you were to use three along the 44” run (one centered) they would be less obtrusive than a piano hinge and nearly as strong.
Just another idea, but I think Paul has the winning suggestion.
How about a guitar case hinge??
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
