To MacGuyver, or not to MacGuyver... That is the question.
Forum topic by Evangogh posted 08-23-2016 02:58 PM 835 views 0 times favorited 5 replies Add to Favorites Watch
View Evangogh's profile
129 posts in 1260 days
08-23-2016 02:58 PM
Topic tags/keywords: i lost safety yellow tab power switch lathe replace replacement make macguyver fix
I lost the yellow safety tab that clicks into power switch for my lathe (sorry, I don’t know the terminology). Does anyone know where I can get a replacement? Or is it possible to make one?
And yes, I have been using a tab from another tool in the meantime, I just want a more permanent fix.
-- Turn on, brothers and sisters!!!
5 replies so far
View Woodchuck2010's profile
706 posts in 788 days
#1 posted 08-23-2016 03:03 PM
Contact the company that made your lathe.
-- Chuck, Michigan,
View RandyinFlorida's profile
244 posts in 1997 days
#2 posted 08-23-2016 04:13 PM
Go to Amazon. Type in Safety Paddle Switch. You didn’t say what brand your lathe was. You might just replace the whole switch assembly.
-- Randy in Crestview Florida, Wood Rocks!
View JBrow's profile
1340 posts in 850 days
#3 posted 08-24-2016 02:41 PM
If the lathe is a Craftsman, which uses the yellow removable switch safety keys, I recall seeing replacements in a two in the Sears store which would probably fit. However that has been several ago. Checking may reveal whether these are available in you local store. If the lathe is not a Craftsman, maybe the Craftsman safety key would still work. Again checking the web might give you some idea whether it might fit. As recall the two pack was fairly inexpensive.
View bbasiaga's profile
1154 posts in 1925 days
#4 posted 08-24-2016 06:06 PM
There are precious few things in this life that are absolutes. But when given the opportunity to be MacGuyver, the answer is always yes. Just make sure you aren’t actually being Red Green. It’s hard to tell in some cases, until it’s too late.
View rwe2156's profile
2834 posts in 1410 days
#5 posted 08-24-2016 06:16 PM
Real machines don’t have safety tabs…......LOL
If you’re worried about kids, throw the breaker or unplug.
