Bandsaw blade size
Forum topic by rmh09 posted 08-23-2016 03:38 AM 615 views 0 times favorited 6 replies Add to Favorites Watch
View rmh09's profile
rmh09
22 posts in 2746 days
08-23-2016 03:38 AM
Topic tags/keywords: bandsaw
Seriously – please…I asked the question in someone else’s post about band saw blade size. I have a Laguna 1412 and plan to resaw with it. The mfr’s specs say 3/4in is the max size. I have seen advice to go to 1in. What is the risk or implication of exceeding the specs?
-- Randy
View MrUnix's profile
MrUnix
6830 posts in 2256 days
#1 posted 08-23-2016 03:45 AM
I have a Laguna 1412 and plan to resaw with it. The mfr s specs say 3/4in is the max size. I have seen advice to go to 1in. What is the risk or implication of exceeding the specs?
- rmh09
Won’t fit and/or you will probably break the machine trying to get it tensioned properly. But it’s your machine – so if you feel the need, ignore what the manufacturer says and go for it!
View BobAnderton's profile
BobAnderton
273 posts in 2847 days
#2 posted 08-23-2016 03:51 AM
Hey Randy. I think the risk of using too wide a blade is that the saw won’t be able to adequately tension a too wide blade and it will give you worse results than a narrower blade properly tensioned. There is a limit to how many lbs of force a given saw can apply to the blade and the wider the blade is the less lbs/inch you can generate. A 1/2 inch resaw blade will work fine, to tell the truth, better than a 1” blade on a saw that isn’t built for it.
-- Bob Anderton - Austin, TX - Nova 3000 lathe, Alaskan Mark III mill, Husqavarna Saw
rmh09
#3 posted 08-23-2016 04:07 AM
Well .. I thought that the mfr’s put specs on for a reason. I swear I saw a couple of days ago a least two recommendations for 1in blades on the 1412. I am just getting started with my bandsaw and want to try to use best practices. I have the 1/2 blade and will stick with that. Thanks for the responses!
Randy
-- Randy
View Andre's profile
Andre
1923 posts in 1863 days
#4 posted 08-23-2016 04:13 AM
I have a General 17” and only use a 1/2” 3 tpi blade, works just fine. Unless you only resaw with the saw better to keep a more general purpose blade on, but maybe you like changing blades for every cut?
rmh09
#5 posted 08-23-2016 04:22 AM
LOL … no changing blades for me. I have barely even used the thing! I also got a 1/4in blade for when I want to do some serious curves. Right now the 1/2in will cover anything I have planned. Thanks again!
-- Randy
View nightguy's profile
nightguy
213 posts in 719 days
#6 posted 08-23-2016 04:38 AM
1/2inch wood slicer for resawing , more tension is worse then not enough.
http://www.highlandwoodworking.com/woodslicer12resawbandsawblades705to137.aspx
