ID this trim?
Forum topic by brandongb posted 08-22-2016 05:57 PM 487 views 0 times favorited 3 replies Add to Favorites Watch
View brandongb's profile
brandongb
2 posts in 1492 days
08-22-2016 05:57 PM
Topic tags/keywords: question jig
First post, because my wife won’t let me make furniture until the house is remodeled. I picked up a bundle of these and have enough to finish all the upper trim, doors, and windows, but not enough for the floor. Here are all the clues I have:
1. I picked them up approximately 120 of these boards at my local HfH ReStore. This suggests some kind of bulk building material dropped off by a contractor (fence pickets??).
2. They came in lengths from 4 to 4.5 feet, most of them very close to 4’. They vary in thickness from 1/2 to 9/16” and in width from 2 5/8 to 2 11/16”.
3. They don’t smell like much. Basement? Though I’ve never smelled cedar, someone told me it was kind of similar.
4. They’re rough-sawn, as pictures show. The one lighter section is freshly sanded,
Does anyone have an idea? I’m anxious to get this done and do some woodworking.
3 replies so far
View bondogaposis's profile
bondogaposis
4524 posts in 2221 days
#1 posted 08-22-2016 06:05 PM
My guess if they are fence pickets is western red cedar.
-- Bondo Gaposis
View splintergroup's profile
splintergroup
1804 posts in 1092 days
#2 posted 08-22-2016 07:15 PM
Kinda straight grained for cedar, perhaps lauan?
brandongb
#3 posted 08-22-2016 08:36 PM
I think you nailed it, splintergroup! After being able to search for lauan (which I never would’ve suspected because I only knew about it in plywood form), I found these 4 7/8” wide boards sold for use as door jambs (approximately double the width, which I can split in half). They look VERY similar, are a common building material (as suspected), and, even better, are still pretty dang cheap when bought new instead of at the ReStore. Thank you guys so much, I knew I could count on an answer on the forum. :)
A Menard's link if you’re curious to compare. Thanks again!
