Finishing - Dye + Stain
Forum topic by Michael James posted 06-03-2010 07:02 PM 1194 views 0 times favorited 6 replies Add to Favorites Watch
View Michael James's profile
Michael James
89 posts in 2954 days
06-03-2010 07:02 PM
Topic tags/keywords: finishing red oak aniline dye oil-based stain
LJ’s,
This is a tough topic to search so I thought I’d try to solicit some opinions. I’m at the finishing stage for a red oak bunk bed I made my son and need some help.
I was planning on spraying the project but realized I just don’t have enough space to set up my spray area for this project – it’s just too big!. My thought was to use an aniline dye and glaze similar (in process) to my coffee tables but with different colours. I really liked the glaze look on these tables and wanted something similar on the bed. I realized last night that there is just not enough room to spray and allow for drying in my small, one car garage.
That being said, I’m leaning toward this process:
Distilled water to raise grain > Water-based Aniline Dye > Minwax Oil-based Stain > shellac > topcoat (probably some type of poly)
Before I completely ruin the bed is there anything I should realize? Has anyone done this before? Is there anything I could consider with the colours?
I have a test piece started, but that’s not substitution for experience on a large piece.
Thanks,
MJ
-- Michael James - www.michaeljames.ca
116906 posts in 3483 days
#1 posted 06-03-2010 07:06 PM
I would put the Shellac on after the dye so you have a good base for the oil base stain.
Michael James
#2 posted 06-03-2010 07:11 PM
Would adding the Shellac prevent the stain from absorbing? Sorry, I’m a bit new to this…
View paphman's profile
paphman
21 posts in 2828 days
#3 posted 06-03-2010 11:01 PM
Michael,
I am new to woodworking but have done some refinishing. I would recommend using an oil based dye and not the water based. The oil is much more color fast than the water based. The sun can do a real job on the water based dyes. Just a thought.
Dale
View levan's profile
levan
472 posts in 2885 days
#4 posted 06-04-2010 08:21 PM
Hey MJ Have you considered moving out doors to spray. Since you are happy with the coffee table finish I would figure some way to repeat the process. The lacquers I work with are dry in 15 min. Just my 2 cents
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
Michael James
#5 posted 06-04-2010 09:00 PM
Lynn – I actually haven’t thought of that. I guess I was more concerned about containment of the overspray. If it falls on my tarps etc. in the garage, there’s no worries but what if the overspray goes to the neighbours. I just use the critter sprayer so it’s not a really advanced system.
I just finished up my test piece and liked it but unfortunately, it didn’t pass upper management so I’ll try a different base coat – she didn’t like the red tones so I’ll try with a brown walnut under tone…
Jim – Seemed to go well with the shellac on top of the dye. Do you know if it would absorb more without it?
View CaptainSkully's profile
CaptainSkully
1566 posts in 3465 days
#6 posted 06-05-2010 12:15 AM
I would go with a gel stain. Do a quick search here on Stickley Finish. I’ve compiled all sorts of info.
-- You can't control the wind, but you can trim your sails
