How to create a smooth edge for a curved opening
Forum topic by BB1 posted 08-21-2016 08:10 PM 652 views 0 times favorited 18 replies Add to Favorites Watch
View BB1's profile
BB1
1135 posts in 844 days
08-21-2016 08:10 PM
So the post yesterday of the tissue box holder http://lumberjocks.com/projects/263338 motivated me to move on one for myself. I have the box part in glue up but am stuck on how to smooth out the opening for the top. I traced the cutout (slightly smaller so the tissue box won’t show) and then my husband cut the opening on his scroll saw. The edges are a bit rough. I fear if I try to sand the edges I’ll have an uneven opening. A trim bit in my router was my next thought but that would require I could construct a decent template. Is there a better way?
18 replies so far
View waho6o9's profile
waho6o9
8189 posts in 2573 days
#1 posted 08-21-2016 08:12 PM
Spindle sander
Files and sand paper is tedious work but the results are worth it.
View BB1's profile
BB1
#2 posted 08-21-2016 08:16 PM
Spindle sander
- waho6o9
Yes, that would be good..but, as of now, I don’t own one so that unfortunately isn’t an option. Maybe a reason to add another tool in the shop.
View BB1's profile
BB1
#3 posted 08-21-2016 08:23 PM
- waho6o9
This is a possibility although I question my ability to make the two sides mirror images. Any hints on the best way to approach? Guessing slow and patient are key.
waho6o9
#4 posted 08-21-2016 08:41 PM
Correct, equal amount of sanding until it’s pleasing to the eye. Tedious but worth it
waho6o9
#5 posted 08-21-2016 08:43 PM
These work okay but I find it difficult to get the opening symmetrical with them.
Hello files and sandpaper. :)
View BB1's profile
BB1
#6 posted 08-21-2016 09:18 PM
Yes…when I checked on cost for a spindle sander my husband laughed and said that would make for a pretty expensive tissue box holder! Looks like I better get to filing and sanding! :)
MrUnix
6704 posts in 2195 days
#7 posted 08-21-2016 09:30 PM
If it’s a one time thing – sanding, filing, sanding, filing some more, sanding… will get you there. If you plan on making more than one, a router, guide bushing and template would make it much easier. You only have to make the template once, and you can use your existing top (once shaped properly) to whip one out easily.
waho6o9
#8 posted 08-21-2016 09:31 PM
Have fun
View BB1's profile
BB1
#9 posted 08-21-2016 09:57 PM
If it s a one time thing – sanding, filing, sanding, filing some more, sanding… will get you there. If you plan on making more than one, a router, guide bushing and template would make it much easier. You only have to make the template once, and you can use your existing top (once shaped properly) to whip one out easily.
- MrUnix
Will have to see how successful I am at getting this one with the filing and sanding. If it wasn’t for the odd shape, making a template would seem to be the way to go. When I see templates used on woodworking shows, it seems the templates just “appear”...I suspect that is the hardest part.
MrUnix
#10 posted 08-21-2016 10:07 PM
It would be easier if you made a positive template of just the oval shape first. Rough cut to shape and final sand on a belt or disc sander right to the line. Once you have the positive, you can use it to make the negative. Fortunately, you only have to go through the pain of getting it shaped properly once :)
I have a negative template to make these ovals on house signs:
(and a positive template for the fishy thing!)
And here are some positive templates for table number bases:
Alternatively, they do sell templates ready to go – if you don’t want to make them yourself. It will give you a limited choice of sizes, but one may be close enough to what you need.
View BB1's profile
BB1
#11 posted 08-21-2016 10:26 PM
Brad – I can see how helpful that would be. Unfortunately as with the spindle sander…no belt or disc sander either (so many tools yet to be added to my shop!). I’m picking away with hand sanding and it is looking better.
View splintergroup's profile
splintergroup
2010 posts in 1218 days
#12 posted 08-21-2016 10:52 PM
I’ve always used templates and my router table. The template is cut into 1/4 masonite. Typically I’ll draw the opening onto a largish piece, then split it on the table saw through the center. This makes it easy to trim the waste up to the line with a bandsaw and makes it easier to shape and refine the curve (I do this with both halves aligned, back to back, in a vice, doing both halves at the same time). Start with a coarse rasp, go finer, finally use strips of sandpaper.
Once done, I’ll double-side tape the two halves to a new piece of masonite for the final template. The hole is cut out with a jig saw, staying just inside the previous template.
It is then to the router table with a bearing guided bit riding on the two part template, the masonite routes nicely.
All done! The wood parts are done with the one piece template double side taped in place, hole cut out as before. Watch the grain direction to avoid tearout (down-hill cuts). I use a bit with top and bottom guide bearings to make this easy.
It’s worth the effort if you plan on making more than several cutouts!
View Snowbeast's profile
Snowbeast
80 posts in 1334 days
#13 posted 08-21-2016 11:04 PM
A sanding drum on a Dremel tool works well and is easy to control. They are just a smaller version of what waho6o9 posted.
View BB1's profile
BB1
#14 posted 08-22-2016 12:10 AM
Thank you for the addition suggestions…no bandsaw or dremel (yet!). Obviously I need to go tool shopping. :)
MrUnix
#15 posted 08-22-2016 12:42 AM
- BB1
Belt sanders and dremels show up on CL all the time in the $10-$20 range :)
