No 80 scraper set up question
« back to Hand Tools forum
Forum topic by bbasiaga posted 08-20-2016 10:20 PM 683 views 0 times favorited 7 replies Add to Favorites Watch
View bbasiaga's profile
bbasiaga
1239 posts in 2081 days
08-20-2016 10:20 PM
Does the bottom need to be flattened like you would on a regular plane?
Thanks,
Brian
7 replies so far
View rwe2156's profile
rwe2156
3036 posts in 1566 days
#1 posted 08-21-2016 02:20 PM
No.
View Tim's profile
Tim
3812 posts in 2047 days
#2 posted 08-21-2016 02:51 PM
I don’t have a solid answer, but I can’t see why it would need to be especially flat. If it were enough out of flat, that could cause problems. But basically if it’s working, then no.
View Bill White's profile
Bill White
5011 posts in 4046 days
#3 posted 08-21-2016 03:41 PM
I just touched up mine because…..........I wanted to.
Bill
-- bill@magraphics.us
View Andre's profile
Andre
1963 posts in 1892 days
#4 posted 08-21-2016 04:33 PM
Of course! A straight blade requires a flat/straight support/platform to reference from?
Each to there own I guess, if its good enough, then its good enough? We all have our own standards! LOL!
View OSU55's profile
OSU55
1790 posts in 2075 days
#5 posted 08-22-2016 02:49 PM
It will work better with a flat sole. It is a form of scraper plane, and should have a flat sole for the edge to reference from. Rounded edges are actually prefered so edges dont catch on the wood. The area surrounding the mouth should be flat, out to radiused or tapering edges. Use a hard flat surface to register the blade edge to the sole.
View dbray45's profile
dbray45
3320 posts in 2862 days
#6 posted 08-22-2016 03:16 PM
Yes – flat back
45 degree edge
burnish the cutting edge
-- David in Damascus, MD
View Don W's profile
Don W
18881 posts in 2653 days
#7 posted 08-22-2016 11:42 PM
It needs to be flat. Whether it needs to be flattened depends if it’s already flat. :-)
