Floating Tenon Material?
Forum topic by KnickKnack posted 06-02-2010 02:04 PM 1866 views 0 times favorited 4 replies Add to Favorites Watch
View KnickKnack's profile
KnickKnack
1088 posts in 3563 days
06-02-2010 02:04 PM
Topic tags/keywords: floating tenon question joining
I’m just about to embark upon a kitchen sink unit – a sort of frame and panel design. I’ve decided to go with floating tenons. The wood is pine with plywood panels.
My question is… what should I make the floating tenon inserts from?
My only choices are pine, oak, ash, beech or plywood. My gut says plywood, but they’re the same guts that make me eat a lot of curry!
Thanks in advance for the “right” answer.
-- "Do not speak – unless it improves on silence." --- "Following the rules and protecting the regulations is binding oneself without rope."
View davidpettinger's profile
davidpettinger
661 posts in 3197 days
#1 posted 06-02-2010 02:21 PM
I wood use beech. Same material they make biscuits out of.
-- Methods are many,Principles are few.Methods change often,Principles never do.
View rance's profile
rance
4258 posts in 3157 days
#2 posted 06-02-2010 02:34 PM
Knick,
More important than the wood is getting the grain direction correct. It needs to go across the joint, not parallel to it. Look at a biscuit closely and you’ll see (although I’ve seen some arranged diagonal). For this reason, I’d suggest NOT using plywood. Typically, use the same wood as the project is made from.
View richgreer's profile
richgreer
4541 posts in 3071 days
#3 posted 06-02-2010 03:35 PM
You will be fine with any of the hardwoods: oak, ash or beech.
117091 posts in 3574 days
#4 posted 06-02-2010 05:20 PM
I agree with all of the above.
