| Forum topic by Drewskie | posted 1088 days ago | 1089 views | 0 times favorited | 12 replies | ![]() |
1088 days ago |
Topic tags/keywords: question Hey out there, I’m a 16 year veteran in the woodworking industry and this is my first go at steam bending. I have a couple of small moldings I need to bend to a radius. I think i have the whole steam box thing figured out, but i am unsure of the whole processing portion. Thanks, Andrew -- I cut it three times and its still to short? www.work-in-wood.com |
12 replies so far
#1 posted 1088 days ago |
Hey Andrew -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#2 posted 1088 days ago |
Jim, Its European Beech. The largest molding is 3/4” X 1 1/4” -- I cut it three times and its still to short? www.work-in-wood.com |
#3 posted 1088 days ago |
I would give it a test run but I’m not that sure about beach because I’ve never tried bend it. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#4 posted 1088 days ago |
Jim, Sounds like a plan. Thanks for the advice. -- I cut it three times and its still to short? www.work-in-wood.com |
#5 posted 1088 days ago |
beech is steambend a lot in Danish design furniture we see it all the time here in Denmark Dennis |
#6 posted 1088 days ago |
I’m sure you’ll get better answers around here, but a general rule I learned was to steam 1 hour per inch of thickness. I’m far from an expert bender, but I’ve made several ox bows over that last few years. Steaming isn’t a real science, it’s the bending that takes work. Be prepared to scrap a few pieces as you learn how much you have to steam, and how fast or slow you have to bend the wood. I usually make the my parts thicker where the radius will be, since I know I’m going to have some cracking on the outside, then carve/sand that away. If the parts are small, or you have a good setup, you could also try soaking the part in boiling water. I tend to go with boiling, since I make maple syrup. I cut a small log at the begging of the syrup season, split and carge the bows while I’m boiling, then when i finish the season, I’ll fill the main pan with water while running the finishing pan, and throw the sticks in the boiling water for 4-5 hours. Good luck, try with scaps first, and make sure your bending jig is ready so that you can get the piece on it fast when you get it out of the steam, and apply a slow constant pressure while bending. Leave the piece clamped in the jig for as long as possible after, since the wood will try to straighten out. I’d also aim to have the radius a little bit tighter that you want. Last note I can offer on bending is that green wood steams easier, too bad we need to wood to dry first! |
#7 posted 1088 days ago |
I can say from experience that Ben’s “1 hour per inch of thickness” method works well on kiln-dried white oak. -- Kinky Friedman on gay marriage: "They should have the right to be just as miserable as the rest of us." |
#8 posted 1088 days ago |
One hour of steaming per inch of thickness. -- "Life's nonsense pierces us with strange relation." Wallace Stevens |
#9 posted 1087 days ago |
Andrew, GO to Fine Woodworking Magazine, search out articles on steam bending by Michael Fortune, and you’ll have the greatest resource known to man. Steve -- Steve in KY. 44 years so far with my lovely bride. Think I'll keep her. |
#10 posted 1087 days ago |
an hour per inch is a good rule of thumb, on beech be sure its as straight grained as possible, beech likes to and can twist when steamed, another thing be sure you have plenty of steam, and while there are numerous methods , I got 2 of the Earlex wallpaper steamers, ( 1 1/2 chair backs at 40 inches long), and used them to make the steam, man oh man, these babies put out some steam, honestly, they get the job done, but are about 50 a piece. just google earlex wall paper steamer, i think they even have a little video on it… but again, be sure its wet and hot |
#11 posted 1087 days ago |
Can only offer my experience with a poor man’s method. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#12 posted 1087 days ago |
I’ve also heard that soaking wood in ammonia will make it bend much easier. If you can get your hands on something stronger than household ammonia, it will work better. -- Tony - Anchorage, Alaska |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15818 |
Hand Tools
2040 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6166 |
