My new (used) workbench for $300
Forum topic by Axle505 posted 08-19-2016 12:19 AM 1488 views 1 time favorited 43 replies Add to Favorites Watch
View Axle505's profile
Axle505
143 posts in 984 days
08-19-2016 12:19 AM
Found it in the local classifieds.
—Rockler vices
—select Douglas Fir
—homemade and weighs a ton! (Well, it’s heavy…)
43 replies so far
View Kelly's profile
Kelly
2092 posts in 3093 days
#1 posted 08-19-2016 01:14 AM
Looks nice and it seems not at all a bad deal.
View nightguy's profile
nightguy
213 posts in 811 days
#2 posted 08-19-2016 01:18 AM
Is the top as thick as the apron? I dont know your locality, but seems a bit high$, $200 in my market would be about right, no lower cabinet or drawers, but you could build a fit in modual cabinet with drawers/ shelves to insert below the top.
Axle505
#3 posted 08-19-2016 01:37 AM
Oh, SoCal. A Sjoberg table here is a $550 for less than half the size. The vices alone are $300 retail. Yes, on the apron. Or, it has none—if I understand you.
View jwmalone's profile
jwmalone
769 posts in 851 days
#4 posted 08-19-2016 01:43 AM
I think you got ripped off my man. But since I’m such a nice guy ill buy it from you for what you paid. That way you’re not out anything :)
-- "Boy you could get more work done it you quit flapping your pie hole" Grandpa
Axle505
#5 posted 08-19-2016 01:52 AM
Awfully nice of you JW, but I think I’ll keep her for the moment and cut my losses!
nightguy
#6 posted 08-19-2016 02:03 AM
Doug Fir is a hard and dence Conifer Wood, but soft in MHO for a bench top. Makes nice legs and rails for a hard wood top. I will stand by my original post, $100 to much based on my local.
I made mine, 30” deep, 72” wide/long, Doug Fir legs and upper and lower rails. 3/4”OSB with a 1 1/8 High Density Particle Board bench top, glued and screwed together, with a 1/4” Masonite Tempered screwed on layer.
Made a lower cabinet with drawers and shelves, all said and done, about $300, plus a CL $35 wood vice with quick release.
nightguy
#7 posted 08-19-2016 02:15 AM
This was my model, as I said different top material, and the lower space I put in/filled it with a modular cabinet, drawers on one side shelving with slide out rails on the other side.
https://www.woodstore.net/plans/shop-plans/workbenches/1665-Traditional-Workbench.html
Axle505
#8 posted 08-19-2016 02:17 AM
That’s a beautiful bench.
View BurlyBob's profile
BurlyBob
5919 posts in 2414 days
#9 posted 08-19-2016 02:24 AM
That’s a real nice looking bench. My only beef is the OSB shelf. I absolutely hate OSB and in spite of that it’s what I used for the walls and ceiling in my garage. Go figure.
Axle505
#10 posted 08-19-2016 02:28 AM
At some point I’ll replace it. Yeah. Right now, I’m gonna clean it up and flatten it.
nightguy
#11 posted 08-19-2016 03:07 AM
At some point I ll replace it. Yeah. Right now, I m gonna clean it up and flatten it.
- Axle505
What the top or lower shelf?? if the top flatten and get Masonite Tempered Masonite board for a hard top and sacrificial, if just screwed on with counter sunk flat heads so yoou dont harm a plane blade.
Axle505
#12 posted 08-19-2016 03:10 AM
The lower self.
Hm. Masonite….
nightguy
#13 posted 08-19-2016 03:29 AM
The lower self.
Hm. Masonite….
- Axle505
Well I was referring to the top, whey flatten a lower shelf?
Axle505
#14 posted 08-19-2016 03:38 AM
Sorry, got confused.
nightguy
#15 posted 08-19-2016 03:44 AM
- nightguy
Forgot to say, that I bordered the top with 2” White Ash the same thickness as the finished top.
showing 1 through 15 of 43 replies
