my first time using shellac...
Forum topic by mzimmers posted 08-19-2016 12:08 AM 1095 views 1 time favorited 15 replies Add to Favorites Watch
View mzimmers's profile
mzimmers
202 posts in 4057 days
08-19-2016 12:08 AM
...isn’t working out quite as I’d hoped for. The wood is rosewood, and I read in a few places that oily woods do well with shellac, so I got a can of Zinnser Bullseye (clear). It’s already thinner than water, and when it dries, it’s shinier than I thought it would be.
Am I putting it on too thick? I do have a tendency to do that. (I’m wiping it on, but could switch to brush.)
I generally like to work in the sunlight, so I can more readily see any imperfections. It’s quite hot out right now and the stuff is drying super fast. Is this a mistake on my part?
My plan at this point is to buff it with 0000 steel wool and spray it with some Deft lacquer, and be done. Any suggestions?
Thanks, guys.
mz
-- M. Zimmers
15 replies so far
View Aj2's profile
Aj2
1712 posts in 1939 days
#1 posted 08-19-2016 12:22 AM
I think your putting it on too thick.
Many thin coats 15+ that you can barely notice.
The stuff in the can is junk.Compared to fresh flakes.
But if you must at least get Dewaxed.
Aj
-- Aj
View lumberdog's profile
lumberdog
245 posts in 3409 days
#2 posted 08-19-2016 12:25 AM
Fresh out of the can it is too thick, thin in down with denatured alchohol and apply in thin coats. you can rub it out with steel wool. The dewaxed flakes are better.
-- Lumberdog.. Morley, Michigan
View nightguy's profile
nightguy
213 posts in 804 days
#3 posted 08-19-2016 01:12 AM
Are you using The Zinzar Seal Coat? that is clear and dewaxed, and a 2lb cut. The Zinzar Shellac is a 3lb cut, and Clear and Amber have wax in them. If it is cloudy when stirred, it has wax in it.
Plus you are working it in sunlight, drys supper fast, another problem. High humidity can cause it to dry cloudy also.
mzimmers
#4 posted 08-19-2016 01:16 AM
Thanks for the replies, guys. This is what I’m using:
https://www.rustoleum.com/product-catalog/consumer-brands/zinsser/interior-wood-finishes/bulls-eye-shellac/
I’ll thin it more (already have once) but I think at this point, maybe I should just buff it and spray it with lacquer, unless anyone thinks this is a bad idea.
-- M. Zimmers
nightguy
#5 posted 08-19-2016 01:45 AM
mzimmers
#6 posted 08-19-2016 01:48 AM
Hi, Nightguy – a minor correction: I wasn’t spraying. I was wiping on, and it was definitely wet…for about 2-3 seconds (literally).
I moved it indoors, and tried again. The results were better, but still not what I was hoping for. I can try thinning it again.
What is the significance of the presence/absence of wax?
-- M. Zimmers
nightguy
#7 posted 08-19-2016 03:01 AM
Hi, Nightguy – a minor correction: I wasn t spraying. I was wiping on, and it was definitely wet…for about 2-3 seconds (literally).
- mzimmers
Non wax Shellac is a bit harder when it dries, and if using it for a Sealer over something, exp oil stain, dye, BLO, it will take another finish oil/water Poly, lacquer, better then waxed.
One of the fastest finishes, BLO cut a bit with MS or MinWax Natural Stain, which I think is basically the same, wipe on to “pop” the grain contrast, wipe off, and Seal Coat Shellac to seal then what ever product or just more coats of Shellac, drys fast, recoat in about 2-4 hours depending on temp and humidity.
nightguy
#8 posted 08-19-2016 03:22 AM
- M. Zimmers,
I HIGHLY recommend this book, get the soft cover, and save a few $, it is my finishing bible, he explains all types of finishes, trouble shooting problems,, stains, dies, applying, repair ect. It will money well spent.
View tomd's profile
tomd
2166 posts in 3911 days
#9 posted 08-19-2016 04:08 AM
I don’t know what kind of finish you where looking for but my experience is rosewood has very large pores and it will take a lot of finish to fill those pores. If it is a small project you might do a French polish since you already have shellac. If a large project you may want to fill the pores then finish or just be happy with the finish you have now.
-- Tom D
nightguy
#10 posted 08-19-2016 07:42 AM
- M. Zimmers,
- nightguy
Opps, never added the link
http://www.barnesandnoble.com/w/understanding-wood-finishing-bob-flexner/1111886330?ean=9781565235489&pcta=n&st=PLA&sid=BNB_DRS_Core+Shopping+Textbooks_00000000&2sid=Google_&sourceId=PLGoP223&k_clickid=3x223
View OSU55's profile
OSU55
1856 posts in 2131 days
#11 posted 08-19-2016 11:51 AM
Here's an article by Jeff Jewitt on Shellac. He has several good articles on finishing on his website, and has written books. Search for him on you tube as well. He and Flexner have been my prime resources for finishing.
View AlaskaGuy's profile
AlaskaGuy
4476 posts in 2450 days
#12 posted 08-19-2016 03:26 PM
Just wondering. It come in a spray can and your wiping it on, why not spray it on.
mzimmers
#13 posted 08-19-2016 04:41 PM
- AlaskaGuy
Mainly because I excel at creating unnecessary work for myself.
I did just apply the first two coats of lacquer…it looks really good, so I guess all’s well that ends well.
Thanks for all the input from everyone.
mz
-- M. Zimmers
View Nikki's profile
Nikki
80 posts in 913 days
#14 posted 08-22-2016 02:53 AM
- AlaskaGuy
- mzimmers
Lol! Don’t we all!
View shipwright's profile
shipwright
8085 posts in 2939 days
#15 posted 08-22-2016 03:19 AM
If you want a slower dry in the heat you can sub isopropyl alcohol for the ethyl (DNA). I actually like it better. Just make sure you get a very high percentage like 98-99%. “Rubbing alcohol” is generally about 29% water. I buy a 99% isopropyl that sells as horse linament.
