Zero clearance insert
Forum topic by Vern Leonard posted 08-18-2016 01:40 PM 715 views 0 times favorited 6 replies Add to Favorites Watch
View Vern Leonard's profile
Vern Leonard
3 posts in 2611 days
08-18-2016 01:40 PM
I am a long time lurker at this site. I recently purchased a new rigid table saw r4512. This is a major upgrade for me. It was a beast to move and assemble by myself but doable. My first task was to make some zero clearance inserts. The plate is very thin so I opted to use some 3/16 thick white board from home depot and still had to mill about.020 off the edges to fit flush. First one is done with the exception of extending the slot for the riving knife.
View Planeman40's profile
Planeman40
1176 posts in 2758 days
#1 posted 08-18-2016 02:18 PM
I recently made a zero clearance insert for my Hammer sliding table saw out of aluminum as the shape of the hole around the saw blade was of an irregular shape and long and not very wide. Works (and looks) beautifully! Aluminum can be easily cut with a carbide saw blade. I just made the insert with no saw slot, lowered the saw blade all the way, installed the aluminum insert, then started the saw and slowly raised the blade to cut the saw slot.
Planeman
View FlushTrimBit's profile
FlushTrimBit
19 posts in 656 days
#2 posted 08-18-2016 02:59 PM
How did you mill it, with a bandsaw?
Vern Leonard
#3 posted 08-18-2016 03:15 PM
I should have said thickness instead of edge. Which I did on my router table.
I cut the shape close on the band saw then taped the original throat plate to the new one and used a flush trim router bit and the router table to get the finished size.
View skatefriday's profile
skatefriday
416 posts in 1479 days
#4 posted 08-18-2016 04:07 PM
- Vern Leonard
Bingo. A jigsaw works for the rough cut also if you don’t have a bandsaw.
runswithscissors
2751 posts in 2022 days
#5 posted 08-19-2016 12:23 AM
Easy way to extend the slot for the riving knife: reinstall the original throat plate; flip the ZCI end for end; move the fence over so the blade comes up through the ZCI blade slot; finish the cut.
View Woodknack's profile
Woodknack
11619 posts in 2377 days
#6 posted 08-19-2016 09:23 PM
Good job on the inserts. I always thought it was dumb they have rounded ends. I suppose that is to prevent corners from catching but still a PITA.
