| Forum topic by Olaf Gradin | posted 237 days ago | 227 views | 0 times favorited | 9 replies | ![]() |
237 days ago |
Topic tags/keywords: t-bolts jig measurement In the continuing saga of inexact things like dimensions and numbers, I’ve found another curious example. On a 5/16” bolt, what exactly is 5/16”? It’s not the diameter – I’ll tell you that. Take a look at the attached pictures and help me understand how to pick out the appropriate bolt for my application…
-- It takes a viking to raze a village. &mdash Blog'r: http://www.gradin.com |
237 days ago |
Your calipers appear to be reading 3/16”. -- What exactly is "The Move" and who are you calling a "Quirky Jerk"? -- http://www.north40custom.com |
237 days ago |
True enough! I didn’t realize how to read them – I was reading the outside ring as 64ths, which is the source of my problem. That would explain some similar problems I’ve had too. Maybe I should switch to day-shift woodworking… -- It takes a viking to raze a village. &mdash Blog'r: http://www.gradin.com |
237 days ago |
These fancy machines that make you have to calculate and convert. -- Karson Southern Delaware karson_morrison@bigfoot.com |
237 days ago |
Believe me, I’ve misread my share of measurements during the day-shift! My calipers only have 100ths on the dial, so I have to have a conversion chart on the wall … I can’t remember the decimal equivelant of 17/32! -- What exactly is "The Move" and who are you calling a "Quirky Jerk"? -- http://www.north40custom.com |
237 days ago |
Others have pointed out the conversion error, but I’d toss out there that far too often we measure as though the number is the important thing. Why not make the slot the width you feel comfortable with, measure the inside as you have, keep the calipers at that width and go find a bolt that fits between the other fingers of the calipers? In most cases in woodworking the numbers aren’t nearly as important as the “feel” of the piece, and often I don’t get that ‘til after I’m making sawdust. -- Dan Lyke, Lagunitas California, http://www.flutterby.net/User:DanLyke |
237 days ago |
Geez, if I only had a dollar for every time I misread my tape or a pair of calipers…or the dial on a machine, etc. etc. Whats that old adage…measure twice, cut once, still f**k it up! As far as the calipers are concerned, get yourself a set that reads in fractions. When I worked in a cabinet shop my boss forced me to use only decimal calipers..he had some European machines ( planer, panel saw, shaper) and he wanted me to get used to doing conversions. I hated it..I was always staring at a conversion chart, and double and triple checking myself on measurements. This is the one I have..its well made, accurate, and it also has the decimal gauge in the center -- Women love me.....trees fear me |
237 days ago |
I completely agree with Dave, sometimes no matter how many times you measure….. And again, you can do what I did….get the calipers for dummies [smile] with the large LCD readout and fractions, but then sometimes I still manage to find a way to do it wrong…LOL -- Jim Hallada, Chesterfield, VA |
237 days ago |
Here is a page I use at work: Use the drop down and select a screw size. -- Andy Stark |
237 days ago |
Here’s what a scatterbrain like me uses, get them free at metal supply stores. http://i190.photobucket.com/albums/z27/mskiba2/ROUTERSTATION039.jpg -- MARK IN BOB, So. CAL |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1104 |
1482 |
103 |
283 |
95 |
Woodworking Trade & Swap
197 |
Coffee Lounge
795 |
LumberJocks.com Site Feedback
251 |
