Design help needed - mortise and tenon execution on wide panel
Forum topic by bbasiaga posted 08-18-2016 03:09 AM 1509 views 1 time favorited 6 replies Add to Favorites Watch
View bbasiaga's profile
bbasiaga
1055 posts in 1867 days
08-18-2016 03:09 AM
So I’m planning a project to make some side tables that will have a deep drawer. The way I have it drawn up, the side apron (that holds the front and back legs together at the top, will be about 8” tall. I’d planned to do mortise and tenon construction here, but I’ve read in another thread that a tenon longer than about 3” is doomed to explode at some point in the future.
So how can I execute this joint? Should I make a 3” wide tenon in the middle of the 8” piece and use just that to hold it together? Two shorter tenons, one a the top and one at the bottom, with the middle open? Should I be looking at another type of joint all together?
Thanks,
Brian
View jwmalone's profile
jwmalone
769 posts in 574 days
#1 posted 08-18-2016 03:47 AM
Brain, I was reading the other day about a similar problem. The guy used a breathing tenon(?). the tenon was shorter than the mortis, one dowel at very top tight. then a second dowel mid way, but the hole in the tenon was slightly sloted. finally a 3rd dowel with a larger slot. it held the tenon in tight but allowed for expansion across the width of the tenon. don’t member the web site
-- "Boy you could get more work done it you quit flapping your pie hole" Grandpa
View jerryminer's profile
jerryminer
846 posts in 1313 days
#2 posted 08-18-2016 05:58 AM
I would use a double tenon with a haunch (short tenon connecting the two)—-gluing the top tenon and putting a peg into an elongated hole in the bottom tenon:
View rwe2156's profile
rwe2156
2749 posts in 1353 days
#3 posted 08-18-2016 01:11 PM
^^^ Exactly what I would do!
jwmalone
#4 posted 08-18-2016 02:52 PM
yep that’s what I saw Brain, only it wasn’t a double tenon guess it depends on size the one I saw was a 4 inch tenon same principle. But also he only put glue on the very top of tenon. and it was a fine woodworking or something like tht website not a idiot with tools on utube.
View splintergroup's profile
splintergroup
1810 posts in 1094 days
#5 posted 08-18-2016 06:16 PM
I used the same concept that Jerryminer posted above of army bedside table.
Dowel into each tenon, top tenon glued, no glue-elongated dowel slot in the lower tenon.
Works great! (so far)
bbasiaga
#6 posted 08-22-2016 12:21 AM
I think I can pull that off. Need to get some hardwood dowel stock.
I do have a nice 9” wide board that I could flatten up for this. Any thoughts on whether I should do that, or make a glued up panel instead? I’ve always heard that shorter boards glued up move less, but in this case I’m not sure it matters. Seems like this piece would be well contained and it may not matter.
Brian
