New to LJ.... is there a place where ....
Forum topic by phil1950 posted 12-28-2007 01:00 AM 758 views 0 times favorited 1 reply Add to Favorites Watch
View phil1950's profile
phil1950
5 posts in 3891 days
12-28-2007 01:00 AM
Topic tags/keywords: tip
your own tool adaptation & jigs is located???
For instance, we all use a “Combination Square”,right???
I improved mine when I drilled an extremely small hole, 3/64 diameter, to be specific, in the exact center of the blade, located at exactly One Inch.
Doing so allowed me to use my .9 MM mechanical pencil to draft lines upon wood which was to be cut.
And do it with Extreme Precision.
3/64 allows the metal tube to enter… the “slop factor” is approx .025…. give or take a fly’s wing in thickness.
OK, so which forum does that sort of posting go into????
I enjoy sharing my ideas…. & best of all, I’ve never charged more than a Cyber Cup of (good) Coffee!
Until Next Time,
Keep your Chisels Sharp,
phil
-- Keep your Chisels Sharp.
1 reply so far
View mot's profile
mot
4911 posts in 4123 days
#1 posted 12-28-2007 01:05 AM
This sounds like a good item to put in your blog. With pictures and description it would make for some good reading for sure.
