What is this feature called?
« back to CNC Woodworking forum
Forum topic by jmeter posted 08-15-2016 09:04 PM 910 views 0 times favorited 4 replies Add to Favorites Watch
View jmeter's profile
jmeter
11 posts in 1229 days
08-15-2016 09:04 PM
I’m trying to find out what this feature is called. It has an undercut to allow you to hang it on a screw.
I assume this is CNCed, but want to know what kind of bit is used to create it.
Thanks!!
MrUnix
6931 posts in 2343 days
#1 posted 08-15-2016 09:12 PM
Keyhole router bit:
jmeter
#2 posted 08-15-2016 09:15 PM
Perfect, thanks!
View HerbC's profile
HerbC
1790 posts in 3004 days
#3 posted 08-16-2016 02:28 AM
Hint, use small diameter straight router bit (same diameter as smaller diameter on keyhole bit) to remove as much as possible first, then use keyhole bit to clean up and provide final shape.
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View nightguy's profile
nightguy
213 posts in 807 days
#4 posted 08-16-2016 02:50 AM
cut the slot with a straight line bit first, then the key way bit, they dont take a lot of strain on them.
