help me please
Forum topic by GR8HUNTER posted 08-15-2016 07:23 PM 532 views 0 times favorited 4 replies Add to Favorites Watch
View GR8HUNTER's profile
GR8HUNTER
4001 posts in 736 days
08-15-2016 07:23 PM
Topic tags/keywords: question
I am looking for ideas for a wood rack against a 2×4 shed wall with a low workbench under it I tried to take a picture but its toooo hot out side and camera just fogs up lol any ideas would greatly appreciate them not wanting to spend a fortune on it Thanks all
View jdh122's profile
jdh122
1018 posts in 2841 days
#1 posted 08-15-2016 07:29 PM
A simple way is to use cleats made from 2×4 and plywood that attach to the studs (assuming your wall is not sheathed on the inside). They’re easy to build and rock solid. I copied mine from the wood whisperer, although I doubt that he was the first one to come up with the design: http://www.thewoodwhisperer.com/videos/racking-my-brain/
-- Jeremy, in the Acadian forests
View ralbuck's profile
ralbuck
4570 posts in 2290 days
#2 posted 08-15-2016 07:31 PM
Make about 4—-6/8 foot tall large 2 by 4 T’s Keep adding cross bars. Then leave room for about 2 feet above the Bench area. Put a top(door???) across that and Containers that are easily moved under it!
Hope this gives you some good inspiration. I raid a fence companies dumpster and acquire a lot of very usable materials of all kinds. They are happy t get rid of it; as otherwise it would cost them disposal fees.
That helps me a lot to keep costs way down!
-- Wood rescue is good for the environment and me! just rjR
View lew's profile
lew
12101 posts in 3779 days
#3 posted 08-15-2016 08:55 PM
I built this for the basement shop
It is made completely from 2×4 material. the long pieces tie into the floor (ceiling) joist above. The spacing between the “shelf” pieces is optional. The shelf pieces and the spacers between are all cut with a 5° angles on each end so the shelves tip up slightly. The shelf pieces just slide into the “hole” between the spacers. Mine sets against the wall. I have about 5 of these uprights spaced out over about 10’.
View SuperCubber's profile
SuperCubber
1026 posts in 2308 days
#4 posted 08-15-2016 09:52 PM
I used Jay Bates’ idea, which is 2×4s and electrical metal tubing (EMT). Easy, strong and cheap!
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
