Delta 785 bandsaw questions
Forum topic by tuckhaber posted 08-15-2016 12:45 PM 637 views 0 times favorited 4 replies Add to Favorites Watch
View tuckhaber's profile
tuckhaber
3 posts in 648 days
08-15-2016 12:45 PM
Hey everyone, this is my first post here. Thanks for having me!
I have an old Delta 785 (fairly sure) and I am restoring it. I need to replace the bearings on the bottom and I am wondering if anyone has any experience locating current made bearings that are the same or very close? I have found some that seem might work but they are 1mm larger OD and 3mm thinner. The bore measurement seems to work out fine.
I was thinking about getting them and spinning them on my belt sander to remove the 1mm.
Anyone have anything to add?
View bigblockyeti's profile
bigblockyeti
5120 posts in 1718 days
#1 posted 08-15-2016 10:16 PM
Your best bet is to remove the bearings you want to replace and take the ID, OD and width measurements to source the same thing online or take them to a bearing supplier to match them up. Don’t try grinding them down on your belt sander, you’ll never achieve anything close to what you can get from the factory, it might take a while and you have a good chance of destroying and/or contaminating the bearing to where it won’t work anyway.
tuckhaber
3 posts in 648 days
#2 posted 08-15-2016 11:04 PM
Your best bet is to remove the bearings you want to replace and take the ID, OD and width measurements to source the same thing online or take them to a bearing supplier to match them up. Don t try grinding them down on your belt sander, you ll never achieve anything close to what you can get from the factory, it might take a while and you have a good chance of destroying and/or contaminating the bearing to where it won t
work anyway.
- bigblockyeti
I did all that, but the OD isn’t made at all. I haven’t seen a single bearing that is 1 5/16 OD.
View MrUnix's profile
MrUnix
6709 posts in 2196 days
#3 posted 08-15-2016 11:21 PM
The bearings for the 785 are made out of unobtainium. If the bearings are in fair shape, you can get by re-packing them. Lots of discussions on trying to find replacements for them over at OWWM, but no real resolution that I have seen, other than re-packing.
tuckhaber
3 posts in 648 days
#4 posted 08-16-2016 02:54 AM
- MrUnix
Yeah that’s what I’ve found…
I’d love to just repack them, but one of them is ruined…. All I need is one bearing..
