Forum topic by Post5 | posted 08-15-2016 12:45 PM | 687 views | 0 times favorited | 21 replies | ![]() |
Topic tags/keywords: question Hey guys, I just got an old Dewalt 10” contractors table saw that I’m hoping to use till I have the money for a big guy. Problem is, the fence is bent so I need a new fence. Anybody have any advice on what a good fence would be that’s an easy instal? Thanks |
21 replies so far
#1 posted 08-15-2016 04:02 PM |
Delta T2/T3 is a pretty popular one. I have one that I’m just upgrading out of at the moment, but besides a handful of small annoyances it is a great fence. Can be had new for ~$200. Finding a used-fence can be hard, though if you’re in the Portland Oregon area…. |
#2 posted 08-15-2016 04:22 PM |
I’ve got a Beissemeyer fence on my Unisaw, I love it, although I’ve used a uni-fence before as well and there’s nothing wrong with it either. As long as it’s sturdy and adjustable to keep it square to the blade then any decent fence should do. -- @craftcollectif , http://www.craftcollective.ca, https://www.etsy.com/shop/craftcollective? |
#3 posted 08-15-2016 04:31 PM |
An Incra LS-III precision fence will take you to the next level. Absolute accuracy & repeatability. Of course if this is too repeatable (any 1/32” +-0.002”) any other fence will do . . . M -- Madmark - Madmark2150@yahoo.com Wiretreefarm.com |
#4 posted 08-15-2016 04:43 PM |
Guy just posted this http://lumberjocks.com/topics/175274 -- Shooting down the walls of heartache. Bang bang. I am. The warrior. |
#5 posted 08-15-2016 04:44 PM |
Heh, that was me! I posted the 1st response on this thread, then figured I’d post anyway. My garage is filling up with fences! |
#6 posted 08-15-2016 06:18 PM |
Anybody have any experience with a VEGA? |
#7 posted 08-15-2016 06:50 PM |
That is true but it cost’s 3 times as much as my Early 70’s Rockwell saw I got this year , I will have to find something a Bit Cheaper. Maybe put this on a New TS if I can ever afford that . I will be keeping an eye on this thread since I would like to have something to replace the Standard Fence on my Rockwell. |
#8 posted 08-15-2016 06:58 PM |
Any idea if theT2/T3 would do a direct bolt on replacement for an older Delta/Rockwell 10” contractors saw ? I tried to find out what the spacing on the bolt holes on the T2/T3 are but couldn’t find it. |
#9 posted 08-15-2016 07:01 PM |
I don’t know for sure, but I installed it on a Craftsman 113. It required a few holes to be drilled in the cast iron, which is actually incredibly easy to do. I clamped the rails to the table, marked them, and drilled. I did 3 sizes of bits to make it easier to get through, but it otherwise was really easy. |
#10 posted 08-15-2016 07:25 PM |
Can you measure the distance between the stock holes on the T2/T3 you have ? I would rather not have to drill and tap any holes in the table since I am not really setup to do that. |
#11 posted 08-15-2016 07:46 PM |
I can do that when I get home I think. You don’t actually have to tap the holes, just drill them. The kit comes with nuts for the back of the bolts to attach it. My Craftsman required the nuts. |
#12 posted 08-15-2016 08:18 PM |
Thanks , on my saw the front of the tables is 1 1/2 or 2 ” thick so that would be a pretty deep hole and I am not sure I could keep it straight plus there are other casting supports behind the front that might get in the way of putting nuts on the back of the bolt. It is pretty Busy behind there. |
#13 posted 08-15-2016 08:28 PM |
Yikes! 2” thick is pretty crazy… Mine was just about 1/4” thick. That said, you can drill the rails without issue. I did that in a few cases too. |
#14 posted 08-15-2016 08:30 PM |
I didn’t read all the details of every reply, so apologies if this has been covered, but have we confirmed that this DW saw is a contractor saw (or hybrid), and not a portable jobsite saw? It’d be tougher to fit a full size aftermarket fence on a portable saw. Not impossible, but harder and less worth the time and money IMO. vs: -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#15 posted 08-15-2016 09:02 PM |
Yea , it is real tough on those little Job Site saws with alum or plastic tops. |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28055 |
CNC Woodworking
212 |
Hand Tools
5407 |
Jigs & Fixtures
1418 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4756 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
