Have Some Questions Building This Tool Box
Forum topic by wmgworks posted 08-15-2016 04:13 AM 681 views 0 times favorited 6 replies Add to Favorites Watch
View wmgworks's profile
wmgworks
193 posts in 954 days
08-15-2016 04:13 AM
I’m building a tool tote based off of this design. I ran into a few hurdles today when I tried to cut the pieces. First off, there is a notch in the bottom section that the drawer face fits into when closed. I cut this out with a jigsaw. The cuts aren’t perfectly straight (see the pics). You can see I drifted a bit and also didn’t keep the saw flat on the surface apparently. What is the best way to clean that up? Sand it? Chisel? I have limited tools – a 1” chisel, a palm sander, a circular saw, a small plane (not a block plane but a little bigger) and jig saw.
Second, I cut the pieces out with a circular saw. I used a guide I created but either the guide isn’t square or I didn’t line the guide up correctly because one side piece is slopes up to be taller than the other by 1/8”. I tried clamping the bottom edges flush, clamp the guide down and trim up the ends, but it didn’t really do anything. Should I stick them together with double stick tape and hit the ends with a plane?
Also, what’s a good finish for this type of thing? Just for general protection. It will be inside almost all the time
Thanks!
-- Butchering wood since 2015
View Woodknack's profile
Woodknack
11486 posts in 2348 days
#1 posted 08-15-2016 04:20 AM
1. chisel
2. yes to tape and handplane
View rwe2156's profile
rwe2156
2884 posts in 1449 days
#2 posted 08-15-2016 03:11 PM
What he said ^.
I would add that a part like that is better made from solid lumber than ply.
You can see what happens to it when you screw close to the edge.
wmgworks
#3 posted 08-15-2016 03:15 PM
What he said ^.
- rwe2156
Agreed. We’ll see what happens. I had some left over 3/4” ply from a cabinet repair so I went with that. His original plan used baltic birch so I’m sure it would screw better than what I have. I think originally the guy who designed it used a brad nailer – whic I don’t have.
View Richard's profile
Richard
1916 posts in 2659 days
#4 posted 08-15-2016 03:47 PM
For making cuts like these with a Circular saw get a couple of Speed Squares a small one and a larger one , they are pretty cheap and work very good as guides for it.
That’s actually a pretty neat box for carrying around a few tools for some odd jobs , where did you find it ?
wmgworks
#5 posted 08-15-2016 03:55 PM
That s actually a pretty neat box for carrying around a few tools for some odd jobs , where did you find it ?
- Richard
Good suggestion. I have a small one but it wouldn’t have been long enough for this cut.
I’ve been looking for a good wooden tool box design and found this one on the interwebs. I love the idea. The guy said he uses it to sit on, stand on, set pieces on – all kinds of stuff. It’s got a couple places routed down so he can set screws in the lid, too. I plan on putting my house fixin’ type tools in here so I don’t have to keep going back and forth to the shop for stuff. Below is the link to the article I pulled the plans from. He has a Sketchup file for download here, too.
http://www.garymkatz.com/ChartsDrawings/tool_tote.html
Richard
#6 posted 08-15-2016 04:15 PM
Thanks I will take a look at the plans . And your idea of putting the House Fixing things in is exactly what I was thinking about for it . Just put the most commonly used stuff it and go to the problem and get it done without a lot of running around. I always seem to have Duplicates of a lot of commonly used tools so having some in this for the occasional odd job is not a big deal as it would most often be sitting in the shop anyway if I needed something from it there.
