Which 2 bandsaw band saw blades for curves and resaw on Laguna 1412?
Forum topic by Big_T posted 08-14-2016 07:36 AM 2547 views 0 times favorited 11 replies Add to Favorites Watch
View Big_T's profile
Big_T
119 posts in 1597 days
08-14-2016 07:36 AM
Just ordered a Laguna 1412 a couple hours ago and wondering what is the best value 115” blade for curves 1/4”, 3/8” or 1/2”?
Also a good value resawing 3/4” blade?
I need something that will last as I learn to use the BS, then I can get the good stuff as I get better and more efficient. I’ve read carbide tipped lasts longest but can’t remember which. Many thanks.
11 replies so far
View Post5's profile
Post5
7 posts in 891 days
#1 posted 08-14-2016 07:49 AM
I have the same saw and have been happy with the laguna blades. The 3/4 resaw king gives amazing cuts that only need minor cleanup.
View DaddioShop87's profile
DaddioShop87
10 posts in 892 days
#2 posted 08-14-2016 11:00 AM
I’m using my Laguna 14” SUV band saw strictly for heavy resawing and I’m using the Laguna 1” Resaw King blade. This blade is awesome. It’s giving me cuts that look like they went thru the jointer and it cuts with ease. Highly recommend it.
-- Insanity is doing the same thing in the same way and expecting a different outcome. Chinese proverb - maybe?
Big_T
#3 posted 08-15-2016 09:15 PM
Thanks for the Re Saw King advice.
View Tabletop's profile
Tabletop
138 posts in 987 days
#4 posted 08-15-2016 11:42 PM
I’ve used a band saw for years but never resawing. I now have a bigger/better powermatic 14” and want to start resawing. What do y’all recommend? Woodcraft tried to sell me a 1/2” 3 or 4 tooth blade?? What do y’all think?
View Rayman24's profile
Rayman24
30 posts in 2569 days
#5 posted 08-16-2016 12:02 AM
I just bought a 1/2” 3-4 tooth Timber wolf blade for my Powermatic 14” Band saw…cost about $30 and had good reviews. I will be putting it to use this week.
-- Rayman24
View jobewan's profile
jobewan
33 posts in 1217 days
#6 posted 08-16-2016 12:07 AM
I have a new Laguna LT14-SUV. I bought the 1” Laguna Resaw King blade. It is a really beautiful blade. As Daddio says, the cuts need minimal cleanup and that blade is fast and quiet. I really can’t recommend it enough.
Tabletop – that isn’t a big enough blade for resawing IMHO. I think you want a 3/4” blade minimum – Timberwolf makes nice blades and are available on Amazon iirc. The wider the blade the less you are going to have to correct later on.
Joe
-- Measure Twice, Cut Once - throw it in the woodpile, start over...
View becikeja's profile
becikeja
962 posts in 3053 days
#7 posted 08-16-2016 12:55 AM
I have been happy with results by the Wood Slicer from Highland woodworking.
View rmh09's profile
rmh09
22 posts in 2929 days
#8 posted 08-16-2016 04:07 AM
So…i see some blades at 1in recommended. Just asking but the specs list 3/4 inch as the widest blade. What are the risks of going wider? Thanks!
-- Randy
View NoSpace's profile
NoSpace
153 posts in 1480 days
#9 posted 08-16-2016 04:20 AM
the 1/4 inch blade is obviously going to give the tightest curves. A solid 1/2” blade is good because you can do a little bit of everything. I resaw just fine on my 1412 with a 1/2” blade 8” thick+ stock. I resisted getting a thicker blade because I figured I would tire of changing it all the time so try to do as much as I can with a 1/2”.
The main problem is blade life if you do a lot of resawing so I got a Lennox trimaster, still the 1/2”. The woodslicer is awesome, but blade life/expense—it’s highly questionable.
Tabletop
#10 posted 08-16-2016 06:45 AM
Jobewan, thank you. A friend suggested that very same blade.
Big_T
#11 posted 08-20-2016 06:24 AM
The main problem is blade life if you do a lot of resawing so I got a Lennox trimaster, still the 1/2”. The woodslicer is awesome, but blade life/expense—it s highly questionable.
- NoSpace
Amazon gave me a 3 hour window 9a-12 noon EDT tomorrow so I need to wake up in about 6 hours. I still have not ordered the blade but I know the 1” re-saw won’t work on the 1412, max is 3/4”.
Amazon has the 1/2” TW for only $30, but I will take your advice and that others and get about 5 different brands in the same 1/2” size to test out in the coming months. I am new to band saws so take that comment with a grain of salt.
I have heard good things about Lennox’s longevity so I’ll get me a 1/4” and 3/8” as well for artsy stuff wife has requested on honey-do list.
Thanks to all.
