Do you unplug
« back to Coffee Lounge forum
Forum topic by rhett posted 05-30-2010 06:14 PM 2281 views 0 times favorited 76 replies Add to Favorites Watch
View rhett's profile
rhett
742 posts in 3908 days
05-30-2010 06:14 PM
I know you are supposed to, but I want honest answers. Do you unplug or cut off the power to your TS when you change the blade? Do you think you need to with a magnetic switch?
-- Doubt kills more dreams than failure.
76 replies so far
View nailbanger2's profile
nailbanger2
1041 posts in 3384 days
#1 posted 05-30-2010 06:20 PM
I don’t have a mag. switch, but I always unplug. Routers and SCMS, skilsaw, just about everything but drills.
-- Wish I were Norm's Nephew
View Sailor's profile
Sailor
543 posts in 3506 days
#2 posted 05-30-2010 06:26 PM
.......No I don’t unplug my saw when I change the blade. I feel guilty.
Maybe this thread will convince my otherwise?
-- Dothan, Alabama Check out my woodworking blog! http://woodworkingtrip.blogspot.com/ Also my Youtube Channel's Facebook page https://www.facebook.com/SailingAndSuch
117420 posts in 3818 days
#3 posted 05-30-2010 06:27 PM
No I don’t unplug
View Knothead62's profile
Knothead62
2600 posts in 3202 days
#4 posted 05-30-2010 06:28 PM
I unplug any corded power tool when changing blades, bits, etc. I unplug everything when I’m not working in the shop. One of my plugs is operated from a switch where most of my drilling is done.
View noicing's profile
noicing
17 posts in 3260 days
#5 posted 05-30-2010 06:35 PM
Yes I always do. Even though I have to lay on the floor and reach under my out feed table to unplug. I am tempted not to, I have put my thumb into the blade and took a chunk out of it. Memories of the nurse at the hospital scrubbing the open wound helps motivate me to always unplug. Also recently when doing something away from the blade under my table saw (Delta Unisaw) my thumb inadvertently bumped the recessed on switch so that is another reason I always unplug.
Rick
-- Rick
16281 posts in 4459 days
#6 posted 05-30-2010 06:40 PM
Guilty as charged.
View dmoney's profile
dmoney
191 posts in 3320 days
#7 posted 05-30-2010 06:48 PM
No I don’t :(
-- Derek, Iowa
View BOB67CAM's profile
BOB67CAM
269 posts in 3312 days
#8 posted 05-30-2010 06:51 PM
i never unplug the TS mainly because the switch cant be “bumped” on, i do unplug the router because while fumbling it arout i could bump it on
side note on the TS theres alot of times when ill reach adjust hight and by habit grab the switch instead, i havent yet turned it on during the habit however in turn, now when im ready to turn it on it takes me an extra 30 seconds to revisit whether its safe to turn on and gives me time to doublecheck, even tho anyone seeing this “internal mind-battle of OCD” moment would wonder wth im doing..lol
-- if you dont have it, build it, especially when its a stupid idea
View Greedo's profile
Greedo
473 posts in 3201 days
#9 posted 05-30-2010 07:02 PM
i don’t unplug the TS, jointer or bandsaw either!
partly because they have giant 3-phase 380v plugs that are difficult to remove, and mostly because im lazy.
but most of the time i do pusch the emergency stop button, so they can’t start.
i occaionally unplug the router, and always unplug angle grinders. my dad never does that even though he once cut 2 fingers off someones hand who was holding the blade when the grinder started by accident.
View Russ's profile
Russ
142 posts in 3440 days
#10 posted 05-30-2010 07:03 PM
I don’t unplug but have a on/off switch with a key to lock out the on. I always lock the switch.
-- Happiness is being covered in sawdust
View Woodwrecker's profile
Woodwrecker
4211 posts in 3816 days
#11 posted 05-30-2010 07:16 PM
Some times yes, sometimes no.
Lazy dog who’s probably gonna pay someday.
View Bureaucrat's profile
Bureaucrat
18340 posts in 3893 days
#12 posted 05-30-2010 07:27 PM
I do. On my Craftsman the power cord to the motor isn’t hard wired to the switch, so I unplug it at the switch. Too convenient not to do it.
-- Gary D. Stoughton, WI
View dustbunny's profile
dustbunny
1149 posts in 3536 days
#13 posted 05-30-2010 07:54 PM
I unplug the power tools when fiddling with them.
I did not do this until recently.
I was setting the angle of the TS blade with a magnetic bevel box,
I needed another 1/2 deg, when I reached for the adjustment handle,
my knuckle just barely brushed the green button, I mean barely,
and the saw kicked on. Needless to say the bevel box is in pieces, literally sawed to bits.
It scared me to think the button was this sensitive to power up.
It could happen anytime just leaning in to change the blade.
I like ten fingers….I unplug now…everything / every time !!
Lisa
-- Imagination rules the world. ~ Napoleon Bonaparte ~ http://quiltedwood.com
View bayspt's profile
bayspt
292 posts in 3945 days
#14 posted 05-30-2010 08:05 PM
I dont on the table saw cause I have a paddle switch that has to be lifted to turn the saw on. dont at the drill press. dont at the lathe. everthing else yes.
-- Jimmy, Oklahoma "It's a dog-eat-dog world, and I'm wearing milkbone underwear!"
View mikedddd's profile
mikedddd
147 posts in 3471 days
#15 posted 05-30-2010 08:32 PM
I don’t on my table saw or router table as they both have paddle type switches, never thought of the drill press but no, everything else I unplug. I’m to clumsy not to.
-- Mike
showing 1 through 15 of 76 replies
