Driil angle holes on Drill Press
Forum topic by rockmolsen posted 08-13-2016 07:40 PM 3931 views 3 times favorited 34 replies Add to Favorites Watch
View rockmolsen's profile
rockmolsen
274 posts in 1718 days
08-13-2016 07:40 PM
Topic tags/keywords: question drill press
I decided its time I finish the deck railing on our new deck. The railing uses 3/4” EMT and on the straight rail no problem. Now because of the angle of the stairs I need to drill 57 degree angled holes to account for the slope of the stairs.
I have been down in my shop this morning coming up zero. My table on the drill press I think only tilts about 40 or 45 degrees. The supports that I’m making are about 34” long so as you move through and I don’t tilt the table the height will increase as I move the piece through?
Any ideas?
-- Rick --------The measure of who we are is what we do with what we have.
34 replies so far
View waho6o9's profile (online now)
waho6o9
8421 posts in 2721 days
#1 posted 08-13-2016 09:32 PM
How about something like this? If I understand you correctly.
View MadMark's profile
MadMark
979 posts in 1597 days
#2 posted 08-13-2016 09:42 PM
The problem is that his angle is past 45° and his table won’t go that far and the angle is too steep to drill safely. As I look at the problem the best solution would be to drill in place with a self countersinking bit.
M
View distrbd's profile
distrbd
2252 posts in 2591 days
#3 posted 08-13-2016 09:49 PM
I would try 33° and see if that works.
-- Ken from Ontario, Canada
waho6o9
#4 posted 08-13-2016 10:01 PM
View Blackjack59's profile
Blackjack59
1 post in 796 days
#5 posted 08-13-2016 10:02 PM
I like waho6o9s jig. Seems it would work perfectly.
View Tony_S's profile
Tony_S
923 posts in 3227 days
#6 posted 08-13-2016 11:34 PM
- distrbd
Yup. 33° is the angle you need.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
rockmolsen
#7 posted 08-14-2016 02:24 AM
Setting to 33 degrees will not work. if you look at the diagram you’ll see why.
Regardless which side you approach from the angle still has to be 57 degrees. The opposing 33 degree angle would be off the 90 degree plane that really doesn’t exist. I believe my only option is to to create a 57 degree angle guide from a piece of stock ( cut a 12 degree bevel on one side and 45 on the opposing side) and manually drill each hole. Just a visual guide to manually drill, 8 holes x 16 pieces = 128 holes. I was going to use a forstner bit but that might walk at that angle. Tomorrow I will make and test the guide jig and report back.
View bbasiaga's profile
bbasiaga
1240 posts in 2140 days
#8 posted 08-14-2016 02:49 AM
I took two pieces of mdf and joined them with a hinge. They were the same size as my drill press table. I can then take a narrow piece of wood and pit it between them. The farther I push it toward the hinge, the bigger the angle I get.
You could do the same I think. Use your bevel gauge to set the top table of the jig at the correct angle, and drill away with your drill press.
Brian
View devann's profile
devann
2246 posts in 2837 days
#9 posted 08-14-2016 03:13 AM
If available have you considered renting a bore buster?
Here’s a photo of one of two of a crude version I made many years ago. It started with the 4×4 & drill press. The 4×4 was drilled then cut the specific miter angle, and then a dado centered the width of the handrail to be drilled. On the top side of the handrail is block of wood shaped for centering handrail. I’s on a threaded bolt that squeezes the handrail to the 4×4.
View BobAnderton's profile
BobAnderton
283 posts in 2935 days
#10 posted 08-14-2016 03:22 AM
Rick, I think you’re getting turned around by the fact that when your drill press table is set at “zero” it drills a hole that is 90 degrees to the face of the board. Look at your diagram again. You want to drill a hole that is 33 degrees away from straight into the face of the board. Set the table at 33 degrees and drill em.
Your angle gauge shows the angle between the post and rail as 57 degrees, but if that blade (rail) were horizontal in the second to last picture in your set it would be reading 90. You’d drill that hole by setting the drill press table to zero.
-- Bob Anderton - Austin, TX - Nova 3000 lathe, Alaskan Mark III mill, Husqavarna Saw
Tony_S
#11 posted 08-14-2016 11:13 AM
Yes it will…I just did it. Example…
One cut on the miter saw for the handrail at 33 degrees.
One hole with the drill press table set at 33 degree’s.
gives you this…
The angle of both stairs and railing is typically measured on a horizontal plane, not a vertical plane. Nothing wrong with measuring on the vertical as long as you realize that you have to convert that angle (57) to a horizontal plane(33) because that’s what your miter saw and drill press table are referencing.
Also, if your going to reference your angle directly off of the newel post, make sure it’s plumb.
waho6o9
#12 posted 08-14-2016 01:31 PM
I thought the posts were going horizontally to match the ones on the upper deck.
Oops.
Tony_S
#13 posted 08-14-2016 02:01 PM
Oops.
- waho6o9
That would be unusual, but could be…it wasn’t specified.
Normally with this type of layout/design, they would either be installed vertically, or on the same plane as the stairs and hand rail.
waho6o9
#14 posted 08-14-2016 02:04 PM
Thanks Tony_S
BobAnderton
#15 posted 08-14-2016 03:23 PM
I think the intent is for the EMT to be going down diagonally at a 33 degree angle, parallel to the handrail.
showing 1 through 15 of 34 replies
