Bed Rail Hook Problems / Fiery Anger of Hellz Heart
Forum topic by UncannyValleyWoods posted 08-12-2016 10:59 PM 800 views 0 times favorited 5 replies Add to Favorites Watch
View UncannyValleyWoods's profile
UncannyValleyWoods
542 posts in 1916 days
08-12-2016 10:59 PM
So, I’m finishing up a king bed.
Against my better judgment, I decided to install these italian bed rail hooks instead of going with the bolt technique.
http://www.leevalley.com/us/garden/page.aspx?p=67916&cat=3,40842,43730&ap=1
They are installed properly with enough space mortised out on the back side for the hooks to fit into the mortises flush.
However, when I try to assemble the bed, the hooks are somehow failing to lock in properly and this has led to some unfortunate falls and some un-choice words hurled at my wife who was supposed to be helping me hold the head board in place.
I even went as far as the drag the entire king bed back to the garage, pull the hardware, make the mortises even deeper and still no luck getting the hooks to latch properly.
Should I just go at these damn things with a mallet, or am I dealing with poorly designed hardware that I should have known better than to use from the get go?
-- “If Jesus had been killed twenty years ago, Catholic school children would be wearing little electric chairs around their necks instead of crosses.” ― Lenny Bruce
5 replies so far
View JBrow's profile
JBrow
1365 posts in 972 days
#1 posted 08-13-2016 02:34 AM
UncannyValleyWoods,
After apologizing to the wife and before whacking anything with a hammer, trying to see why the rail plate fails to seat properly could be tried, at least that would be my approach. If the bedrail half of the connector pair is removed from the bedrail, then the bedrail half could be dropped into place onto the half that is still connected to the headboard and footboard. Without the bedrail blocking the view at the connection, perhaps you could see what is going on and why it does not lock into place.
View Chris208's profile
Chris208
239 posts in 2322 days
#2 posted 08-13-2016 07:12 PM
It looks like the hardware isn’t flush with the surface of the wood. It should be.
You can shim it to flush.
woodbutcherbynight
5240 posts in 2461 days
#3 posted 08-15-2016 03:14 AM
I have had hardware that required some tweeking over the years. Might be a bad casting has given you too little clearance for the hook to come down into the latch. Only way to know is to look at it closely . One possible fix is some time filing it down if the gap is too small to grab correctly. One of many possible issues but this is something that I have come across both at work on cars and trucks as well as wood projects at home.
Maybe leave the wife out of the equation and call a friend. I am just saying…...
UncannyValleyWoods
#4 posted 08-15-2016 08:46 PM
This turned out to be the problem….I wasn’t having issues with flush fitting… I could watch the hooks go in and set in place, but there simply was not enough space between the mounting surface and the hooks to actually grab the corresponding mortise. So they would set in and then literally just roll right back out… It was one of the strangest things I’ve ever seen.
I went the next day and picked up some bolt mounts and synched it up tighter than Mitch McConnell’s world view.
The wife is cool. She’s a military officer, so it takes more to ruffle her feathers than watching her husband freak out over a piece of furniture.
woodbutcherbynight
#5 posted 08-16-2016 01:32 AM
Good to know you found the problem.
