What do you think of Kreg insert plate?
Forum topic by distrbd posted 08-12-2016 12:44 AM 1618 views 0 times favorited 21 replies Add to Favorites Watch
View distrbd's profile
distrbd
2252 posts in 2472 days
08-12-2016 12:44 AM
I’m planning on build my own router table and was thinking of using a Kreg insert plate for my Triton router ,the price is reasonable but I’m not sure if I should pay a bit more and get an aluminum insert plate instead of phenolic, my only concern is if it’s possible the (3/8” thick) phenolic plate would sage.
Does any of you use a Kreg plate with your router permanently attached? if so, how long have you had it ? do you notice any amount of sagging in the plate?
I would appreciate all comments.
ken.
-- Ken from Ontario, Canada
21 replies so far
View Dabcan's profile
Dabcan
255 posts in 2696 days
#1 posted 08-12-2016 01:44 AM
I’ve had mine for 2.5 years with a 3hp triton router attached. The plate is still flat. I bought the setup used so it’s likely at least a couple of years older than that, so I don’t think you need to worry.
-- @craftcollectif , http://www.craftcollective.ca, https://www.etsy.com/shop/craftcollective?
View Jerry's profile
Jerry
2656 posts in 1673 days
#2 posted 08-12-2016 01:56 AM
I’ve had mine for two years with a 3 horse 1/2” Milwaukie router attached to it and it’s still perfectly flat. If I had it to do over again though, I’d go with metal because the phenolic can burn in some cases, mine did.
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
distrbd
#3 posted 08-12-2016 03:06 AM
Thank you Dabca, Jerry, so it sounds like I shouldn’t be too concerned about it sagging.
Jerry , didn’t know phenolic could burn ,i suppose it would be as a result of friction? never thought or even considered that as a possibility , thanks for the heads up.
View KnickKnack's profile
KnickKnack
1090 posts in 3592 days
#4 posted 08-12-2016 11:40 AM
You may find Lumberjocks this review to be of interest.
-- "Do not speak – unless it improves on silence." --- "Following the rules and protecting the regulations is binding oneself without rope."
distrbd
#5 posted 08-12-2016 02:03 PM
- KnickKnack
Very interesting, I’ve read a few comments about some of these phenolic plates not being absolutely flat(different brands,not all Kreg ) but it’s is something to watch for .
Thanks for the link.
View HokieKen's profile
HokieKen
5239 posts in 1164 days
#6 posted 08-12-2016 02:58 PM
I put a Kreg plate in my router table a little over a year ago. I love it and it’s still dead flat. I highly recommend the leveling mounts that Kreg sells for the plate as well. The only complaint I have with the system as a whole is the insert rings. They aren’t always flat and sometimes that can be a problem with small pieces. I will say that at least the inserts always stay below the plate, none of them stick up and give a lip for the work to catch on. I have a 3.25 hp PC router attached to mine that never comes out of the table. It’s a hoss and the plate’s held it for over a year with no sag. My plate was flat from day one but, I would buy it somewhere that it’s easy to return it if you get one that isn’t. When I was doing my research, it seemed that the Kreg plates are flat for the most part but there are still some that got one that wasn’t. I’d check for flatness before installing it and exchange it immediately if it isn’t flat.
-- Kenny, SW VA, Go Hokies!!!
KnickKnack
#7 posted 08-12-2016 03:49 PM
About 4 1/2 years ago I got a phenolic router plate (not this brand) – this was aggressively, designerly NOT-flat.
So all this discussion of peoples’ plates being “dead flat” is revealing – at least to me. Whilst I still use this plate daily (the router table is the only precision tool I have), I still don’t really like the slight ridge, but, as discussed there, it’s better than a sag.
It was an interesting exchange which may contain some points pertinent to this discussion.
distrbd
#8 posted 08-12-2016 03:56 PM
Hokieken, thanks for your post/comment, the issue of the insert rings being lower than the plate is exactly in the review that Kinickknack linked in post #4.
I have re-searched a bit for this product and from what I gathered (and as you mentioned yourself) , most owners are quite happy with the flatness of the plate but it does happen that a few have been missed,could be a QC issue.
I ordered mine (with the levellers) from Amazon so it shouldn’t be too difficult to return it if I’m unlucky enough to receive an uneven one ,we’ll see how it goes.
Thanks again .
Ken.
distrbd
#9 posted 08-12-2016 04:25 PM
Kinckknack, how are you coping with the Trend insert plate? do you think the idea of having a plate slightly convex is sound or even practical ?,does the weight of a heavy router actually make that plate perfectly flat after a while?
I assume you did not get a response from Trend but this whole subject got me thinking, what other manufacturer has come up with a similar convex router plate I wonder,it does sound logical though to manufacture the plate slightly raised and then let the weight of the router to force it flat.
On the other hand, if the rings are lower than the rest of the plate, we could also remedy that by shimming it to raise them a bit .
KnickKnack
#10 posted 08-12-2016 04:40 PM
On the other hand, if the rings are lower than the rest of the plate, we could also remedy that by shimming it to raise it a bit .
- distrbd
Well. My router isn’t that heavy, and it certainly hasn’t pulled the plate flat – that slight bump is still there. Maybe a heavier router would flatten it (though I doubt it) – but these are “one size fits all” plates, and then it isn’t working for my router, so I’m really not sure of the logic. Which was, of course, why I asked them – but, no, no response – rest assured I have not bought from them since.
I don’t like the slight “rock” you get routing in long pieces when you go over the centre, and I think there are some issues with where exactly to apply pressure – I don’t like my fingers over the bit itself, so I’m always on one side or the other – and usually the pressure shifts as the piece goes through – hence the “rock” as the piece moves from flush on the infeed to flush on the outfeed..
I’m not too impressed with the rings – I rarely use anything other than “smallest”, but when I have removed one or more it’s a bit of pain to get them back and “flat” again – even a morsel under and the piece might “catch” as you go through.
I’d used a simple hole in a piece of fat flat ply for a few years, so I figured I “deserved” to get myself a “real” plate. Whilst I don’t really regret it (once in a while I just needed a bigger hole than I had), I probably wouldn’t buy it again – I estimate that about 80% of all the routing I ever do is with a 10mm or under bit, so I’d just make 2 fat flat ply tops – one with an 11mm hole, for almost everything, and another with a bigger hole for the other 20% of the time. Now I come to think about it, maybe I should do that!
View pintodeluxe's profile
pintodeluxe
5705 posts in 2838 days
#11 posted 08-12-2016 04:48 PM
No experience with the Kreg plate, but I have a Bench Dog aluminum router plate and it is really nice. Various size
insert rings screw into the plate as needed, but I don’t change them much unless I install a really large bit.
HokieKen
#12 posted 08-12-2016 04:56 PM
... So all this discussion of peoples plates being “dead flat” is revealing – at least to me…
- KnickKnack
I should clarify that I probably shouldn’t have said “dead flat” :-/ I didn’t go to the effort of checking it for “dead” flat, I just checked with a straight edge across the diagonals and then laid both sides on a granite surface plate to check for “rock”. Neither method detected any out-of-flatness. I didn’t check it on a CMM or with a planar gauge so I probably should have said “it was flat enough as far as I could tell”.
distrbd
#13 posted 08-12-2016 05:57 PM
Pinto, I thought about ordering one (Bench Dog) but it would have cost me double by the time I receive it(UPS/Brokerage fee/exchange rate) ,I even liked Woodpecker’s plate but same story with the final cost.
I just ordered my Kreg with the levellers, extra miter channel, t-track, casters,I just have to go to HD to get a piece of 3/4”Melamine for the router top,will double the thickness with some plywood.
I hope the insert plate actually has a hole for the Triton lift handle.
Thank you all for responding in this thread.
View Roger's profile
Roger
20928 posts in 2829 days
#14 posted 08-20-2016 01:13 PM
I have this same setup in my router table with an older Hitachi M12V. I purchased it because of a hell-a-cious sale on this and a Woodpeckers table top a while back. I haven’t had any sag problems. If you have any doubts, I’d buy the aluminum plate. That should surely hold any heavy router w/out any problem.
distrbd
#15 posted 08-20-2016 01:42 PM
Thanks Roger, I did order the Kreg plate and now I’m in the process of cutting the Melamine table top , already made a template for that plate and I tell you, it wasn’t easy to cut those( 1.1/2”Dia.)round corners right with no gaps but I managed ,Steve Ramsey's you tube video on this RT plate helped a lot .
