Need help blending light and dark poplar and maple
Forum topic by ErsatzTom posted 699 days ago 433 views 0 times favorited 21 replies Add to Favorites Watch
View ErsatzTom's profile
ErsatzTom
103 posts in 701 days
699 days ago
Topic tags/keywords: question finishing
I made an easel for my daughter (from the NYW plan) and it is all done except for the finishing. The problem is that when I started the project my wife insisted that it should be painted. Since it was going to be painted, I made it mostly out of poplar I already had in the shop but also used a couple of scraps of maple when I ran out of poplar. When I finished the easel, however, my wife decided that she liked it better natural (honestly, I think she was almost as surprised that I successfully got it built as I was). It doesn’t have to be perfect or anything but I think that the especially dark green areas are going to stand out too much. Does anyone have any ideas about the best way to deal with this? Thanks!
Tom
-- Tom, Southwest Florida
View Mark A. DeCou's profile
Mark A. DeCou
1537 posts in 1301 days
699 days ago
Try this trick Tom:
Figure out what color you want the final project to be. Get some wood stain of that color made for you, or off the shelf. I like Sherwin Williams stain, and they can mix it to whatever I want.
Then, I add up to 6 ounces of the stain color to my gallon of clear finish. I like lacquer, but it would probably work on something else like poly if you like that stuff.
Stir in the stain, and apply the finish as usual. The more coats you apply, the more wood color will start to look like your planned stained color.
I have done this process to make the color consistent where wood grains are not. It is sort of like painting the wood, only with a paint that isn’t very opaque. The more coats you spray on, the more it builds and covers the grain and natural coloring of the wood. This process lets the wood grain show through, and also makes the project look like wood finish, not a painted project. I do this method with a spray gun. I don’t know if it would work with a brush, or a rag, but I sort of doubt it.
I was able to use this process successfully on a birch project this fall. Here is a link to the blog where I described the process of yellowing the finish to match the house’s existing finish using this technique:
http://lumberjocks.com/jocks/decoustudio/blog/2163
I was able to use the yellowed lacquer to blend out the various colors of the birch, to a consistent finish.
Hope this gives you some ideas,
Mark
-- Mark DeCou - American Contemporary Craft Artisan - www.decoustudio.com
View Peter O's profile
Peter O
1023 posts in 770 days
699 days ago
Mark is right – this does work with poly, but keep it down to a few ounces per gallon. I spray almost everything, so I can’t say whether it will work with a brush, but I don’t know why not.
Wood dye might work, too, but I wouldn’t recommend that a beginning woodworker mess with dies (dies? dyes? dice? awww, how do you pluralize that word??).
-- http://www.north40custom.com -- http://north40studios.etsy.com --
View SPalm's profile
SPalm
949 posts in 777 days
699 days ago
As the others just mentioned, stain mixed in with the poly will cover most any inherent wood color. You can buy small premixed cans of it at the big box stores.
I don’t think it will look as good for other projects as doing separate coats, but in this case it will, as poplar does not stain so pretty.
ErsatzTom
699 days ago
Thanks for your replies! In my experimenting, I’ve tried some PolyShade I had hanging around which I believe is pretty much what you are talking about. It did a pretty good job of blending the lighter colored poplar and the maple but nothing that I’ve put on the darker green pieces has had much impact on its general shade. It still looks green, but maybe a shade darker. I don’t care if it is a little green, but it is REALLY green. I was thinking about trying to bleach the darkest areas but it seems like a fairly advanced topic and most of the advice I’ve seen on the subject discourages its use.
The largest single piece that is dark green is actually a drawer front so I think I’ll simply remake that since it should take all of 5 minutes. But there are other places where the dark woods is one part of a fairly complicated (for me) piece.
Thanks again for your help!!!
View Catspaw's profile
Catspaw
186 posts in 711 days
699 days ago
Dyes would be correct.
It’s my understaning the the green will fade to brown with time. I know of no poplar that ever keeps its color. Sometimes I think it would be nice to have the poplar stay green and purple. But it never does.
It won’t lighten any, but, the colors will fade to various shades of brown.
Using a UV inhibiting finish would, of course, slow the process.
-- arborial reconfiguration specialist
ErsatzTom
699 days ago
Would intentionally exposing the wood to UV light speed the process? I could put them out in the sun for a couple of days, or I also have some UV bulbs for curing liquid polymer resin stamps.
View Thuan's profile
Thuan
203 posts in 713 days
699 days ago
In the summer, a couple hours is all it takes to turn the green to brown. in the Winter, a little longer.
-- Thuan
View Dadoo's profile
Dadoo
1723 posts in 886 days
698 days ago
Lets see it.
ErsatzTom
698 days ago
Well, it is currently disassembled for finishing. I did have it all put together when I let my wife take a look at it. Here is a shot of all the pieces:
Easel before finish
Here are a couple of shots that highlight the issues. The first one shows the top of the leg assembly. The two smaller end caps are made from maple scraps I had lying around. The side closest to the camera is a greenish (but too dark) piece of poplar while the side behind it really doesn’t have any green in it at all. The second shot shows a side of the tray assembly where you can see that the height extension piece is much darker than the main side piece and the drawer support back has some pretty dark areas as well. Topping it off, I didn’t really pay much attention to the color of the bungs I was putting in. Hey, I was going to paint this thing.
Easel before finish
Easel before finish
I’m still doing a little experimenting. I’m sort of leaning to just putting a clear finish on it and let it be, warts and all.
View Sawdust2's profile
Sawdust2
1186 posts in 983 days
698 days ago
Toads have warts.
Frogs turn into princes.
As this is for your princess I’d get rid of the warts otherwise Daddy is not gong to be happy.
Dadoo
698 days ago
Excellent construction here. You had a great idea to use poplar for a painted finish as it definately don’t stain well at all. I’d stick to that original plan and try and explain to the wife why you chose poplar. You can also incorporate a stained wood (edgeing) to a painted box. The contrast really looks good.
Your daughter is waiting to use this Dad. Gotta get it done.
View doyoulikegumwood's profile
doyoulikegumwood
278 posts in 888 days
698 days ago
ok tom i dont know if anyone has added this im a bit to lazy today to read all the poasts but heres what i do to combat the mean greenie as i like to call it i do a 4 part finish first i pick a color stain i buy it in both normal staine and in a gel youll need shallac and poly first off use the normal stain leting it sit a touch longer on popler the let it dry and put on two coats of shallac let it dry then use the gel stain to even out the color let it dry then poly the heck out of it it takes a while but i love the way finishes turn out when dun this way i hope this helps
-- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more
ErsatzTom
698 days ago
Well, last night I experimented a little more. I took a scrap piece of poplar that was greenish (not the darkest or lightest I have) and left it overnight on top of some UV bulbs with half the surface covered by duct tape. Here is a photo of what I got (I had to play with the tint and exposure to get it to match the actual piece closely):
Poplar uv exposure test
It certainly turn much more brown and maybe a little darker too? If I could get it that shade but lighten it up a bit I might be in business.
ErsatzTom
698 days ago
doyoulikegumwood: That sounds really interesting! I haven’t used either shellac or gel stain so it should be fun to give it a try. Thanks!
View Jim Boisvert's profile
Jim Boisvert
6 posts in 720 days
691 days ago
Use a method that has been around since the dark ages (well, a long time anyway). Seal the wood with a good quality sealer, sand with 300 grit when dry then apply the stain. If the light areas still don’t quite match the dark, apply another coat of sealer, sand and restain the light areas. Then proceed to final finish. I always seal woods like maple and pine before staining to prevent blotchy areas. If you have the means, I have had great success mixing the final finish product with equal parts of the stain and spraying the light areas with a automotive touch up spray gun. When satisfied, apply a couply more coats of clear and your on your way.
-- Jim, Alberta Canada
ErsatzTom
689 days ago
Thanks for everyones help. In the end, I didn’t end up tinting or dying the woods at all. I just couldn’t get it to look very good. Time and experience will fix that, I suppose. I did put the whole thing out in the sun for a couple of days which made most of the green tones brown out a bit. Also, I bleached down the darkest areas a little. That is a bit of a story on its own.
I did a little internet research on wood bleach and it seemed the correct bleach to use for altering the tone of the wood itself is two part peroxide bleach. The articles said that many hardware stores and most paint stores would carry it. Hah! What a waste of time and gas that turned out to be. I tried oxalic bleach but, as I suspected, it didn’t do too much. Out of desperation, I tried the only other two part, peroxide bleach I knew of. Hair bleach. It actually did take it down a couple of notches.
Anyway you can check out my project entry on it if you are interested: Folding Easel for my daughter
View patrick m's profile
patrick m
179 posts in 709 days
689 days ago
Can’t wait to see it finished, I’ve had this problem myself. I end up creating some faux finish or painted grain…
This is an easle for your daughter… Is she’s an Artist maybe it’s time to bring her in on the project and two of you create a new concoction of some new finish. With two coats of jaco bean you can create a pretty cool tiger or flame pattern, by: 1st putting one coat and while wet place your hand will latex glove in a tray of the same color stain. Tap and fan your 4 fingers along the wood…. about every half inch up n down taps moving your fingers the way you want to fan out the flames or stripes.. I did this on a book case, it can turn out really pretty cool with some experimenting.. Patrick
-- PJM.`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º> ""BY HAMMER AND HAND ALL ARTS DO STAND""1785-1974 nyc Semper Fi, Patrick M
patrick m
689 days ago
This may even let the two tones really work for each other, I don’t usually like to hide any maple. But you can create wonders with stain experimenting… May not be what you want to do for this project but thought I’d throw it out there, cause it reminded me of when I went that route and came out pleased.. Look up some faux finish teqniques on line if interested I have a book of faux finishes and antique murals on wood that may give you some other ideas ? I can scan in some pages if you’d like? If not I Hope and am Sure it will turn out beautiful. You put some care into this… Hand made presents are ‘always’ the best.
View Scott Bryan's profile (online now)
20694 posts in 717 days
688 days ago
Hi Tom,
I first worked with poplar when we finished the basement. All the trim and doors were done in poplar and I naively put an oil based stain on them despite suggestions that poplar is best painted (I feel that painting wood is a sacrilege). Like you I had some green areas, but just let it go as I was so frustrated with the project since it didn’t turn out like I envisioned. But to my surprise the green areas gradually turned to a nice deep brown and all the wood is now the same color. I am not sure how long this took since I hadn’t really noticed the change until one day it dawned on me that the green was gone.
If you have the time to wait it should be just fine.
ErsatzTom
688 days ago
Here she is using it for the first time last night:
Artist Gracie
patrick m
688 days ago
Oh man, That’s GREAT! I’m a painter myself.. This is such a great gift. Really, BRAVO ! Nice Job..
Wish you both many HAPPY YEARS of Great Art and Joy! She’ll Be famous one day thanks to this. Just look at her presentation pose , saying see what I’ve created…
