Tradesman Scroll Saw - not running
Forum topic by Mr300 posted 05-28-2010 11:42 AM 1179 views 0 times favorited 7 replies Add to Favorites Watch
View Mr300's profile
Mr300
4 posts in 2797 days
05-28-2010 11:42 AM
I have a Tradesman Variable Speed Scroll Saw. I only used it a few times and it quit working. It has a work light and it is still getting power to the light. The last time I ran it, which was a few weeks ago, it was for about 20 minutes. About 5 minutes later, I turned it back on and nothing. So I waited about 30 minutes and turned it on again, and i it was moving really choppy, not smooth at all. So I left it run for a few minutes without cutting anything and it seemed to work out the choppy problem and started running smooth again. I went to use it 2 days ago and it didn’t start up at all. Does anyone have any suggestions as to what the problem may be? Anything at all would be appreciated.
Thanks
7 replies so far
View davidpettinger's profile
davidpettinger
661 posts in 3076 days
#1 posted 05-28-2010 01:53 PM
Sounds like you might have a brush problem. See if you can remove the brushes and see if the contact point on the armature is clean, or maybe you have a broken wire on a brush.
-- Methods are many,Principles are few.Methods change often,Principles never do.
Mr300
#2 posted 05-28-2010 04:20 PM
Thanks for the information. Is this something that can easily be fixed?
116815 posts in 3453 days
#3 posted 05-28-2010 04:32 PM
Many motors have what looks like large screws on two sides of the motor if there removed you will be able to remove the brushis. Another cause could be a bad smitch or loose wire.
Mr300
#4 posted 05-28-2010 05:51 PM
When you say remove the brushes, do I replace them, or clean them, or just remove them? What function do the brushes do for the motor? What could be wrong with the brushes that is keeping the saw from working? Thanks for the info guys.
davidpettinger
#5 posted 05-29-2010 08:44 PM
Thanks, notottoman. I was late gettin back here.
Mr300
#6 posted 05-29-2010 09:32 PM
Thanks guys, I will check it out and let you know what I found. If I have any other questions, I will be sure to ask. Thanks again
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3461 days
#7 posted 05-29-2010 09:50 PM
Just buy new ones. Their not expensive you may have to grind them in to the shape of your armature or they might spark a bit not serious don’t worry get the supplier to explain it to you.Alistair
