When can I finish the bottom of a giant slab?
Forum topic by Rich Simon posted 08-10-2016 11:27 AM 501 views 0 times favorited 3 replies Add to Favorites Watch
View Rich Simon's profile
Rich Simon
25 posts in 1333 days
08-10-2016 11:27 AM
Topic tags/keywords: finish poly question sapele
Working on a garden bench whose sapele top is 20” wide, 4’ long and nearly 2” thick. It’s heavy.
I put the final coat of Epifanes on top and it looks great. But now I need to deal with the underside and I’m afraid of turning it over to do the work. I have trouble trusting the Rocker bench cookies and particularly the pointed pyramids with something that heavy since they might leave marks (and did when I turned it over during some tests).
I could lay it flat on the table instead, but when can I be sure that I won’t interfere with the top? Is it really a month before the poly is really cured?
3 replies so far
View gargey's profile
gargey
958 posts in 743 days
#1 posted 08-10-2016 12:03 PM
If you’re that scared, wait another day with a fan on it, then flip it over with a blanket on it. It can be dry for practical purposes even if its still curing.
View bbasiaga's profile
bbasiaga
1202 posts in 1962 days
#2 posted 08-10-2016 12:08 PM
I always finish the bottom first because I’m paranoid about thus as well. I agree with the blanket trick. Have used it before. Use one you don’t care about because it is bound to get drips of finish on it.
Brian
Rich Simon
#3 posted 08-10-2016 01:54 PM
Thanks for the replies. I’m mostly gun-shy because the indentations these pyramids left earlier since the top is so heavy. Then after another piece was finished I used the rubber pads themselves but they left a crosshatch pattern in the finish.
