Domino fence not level
Forum topic by Gixxerjoe04 posted 08-09-2016 11:01 PM 514 views 0 times favorited 3 replies Add to Favorites Watch
View Gixxerjoe04's profile
Gixxerjoe04
850 posts in 1811 days
08-09-2016 11:01 PM
Went to use my domino tonight and wanted to make some test cuts to make sure everything was good since I installed the domino plate thing from Seneca to use with my adapters. Cut a couple pieces and joined them together and noticed something was wrong. The right side of the tenon was lower than the left resulting in not flush surfaces which is pretty important. I can force the piece flush, but it shouldn’t be that way and for what I’m doing, that won’t work. Any ideas how to fix this? Was thinking it was the plate so I took it off and it’s still messed up. Another concern is the piece I’ll be making tenons in are only 2 inches wide, half mm different in that small of a piece isn’t good. The pieces didn’t move on me, had them secured and tried multiple different pieces with the same result. Still pretty new to my domino which is why the concern and didn’t find anything in the manual or online, only thing I found how to adjust was the center cursor.
3 replies so far
Gixxerjoe04
#1 posted 08-09-2016 11:08 PM
Also, using the fence reference off the wood hanging off the table so the base plate isn’t hitting anything causing the problem underneath.
View waho6o9's profile
waho6o9
8539 posts in 2811 days
#2 posted 08-09-2016 11:41 PM
http://festoolownersgroup.com
Please specify which Domino you have and the’ll sort it out for you.
http://www.halfinchshy.com/search/label/Domino%20XL%20%28Domizilla%29
Gixxerjoe04
#3 posted 08-10-2016 12:14 AM
Don’t know why i didn’t think about posting it there first haha, thanks for the reminder.
